The ILS in question is in a non-radar environment at an uncontrolled airport. The LOM is the IAF for the approach. Also the LOM is the final destination for the missed approach.why would you need to identify the LOM? On a ILS approach, glideslope intercept is the FAF.
http://204.108.4.16/d-tpp/0712/05582IL17.PDF
Thats the thing about this, I tried to shoot this approach two times the past 48 hours and each time Wichita approach informs me that the LOM, CA NDB is OTS. There are no FDC or local notams for it. Just seems odd that the whole ILS approach is rendered useless because of a cheap NDB OTS.correct. no way to identify iaf, faf, etc. or do the published missed, plus the 'adf required' pretty much says it all. there are no reported notams at this time for lom and/or the approach being ots.
So it's LIFR and you try the approach. Non-radar environment. You have to go missed. So you?Thats the thing about this, I tried to shoot this approach two times the past 48 hours and each time Wichita approach informs me that the LOM, CA NDB is OTS. There are no FDC or local notams for it. Just seems odd that the whole ILS approach is rendered useless because of a cheap NDB OTS.
If an ILS approach has a LOM, which is also the IAF, and in the notes section it stipulates an ADF is required, what would happen if the NDB is permanently out of service? This would render the whole ILS approach useless and would no longer be a valid approach correct?
Yes. Unless you have an IFR certified GPS.
No matter how expensive and sophisticated, an overall system is only the sum of its parts. Remove even a cheap component and the system doesn't work.What I meant when I stated "I thought it was odd" was that the ILS system was relatively expensive to implement and maintain and a NDB is what put it OTS to /U or /A pilots, but thats aviation.
LOL true!No matter how expensive and sophisticated, an overall system is only the sum of its parts. Remove even a cheap component and the system doesn't work.
It's not just aviation. Take your desktop computer. Snip off the end of the plug, worth about 50¢, and see how well it works.
