nosehair
mmWhaa-Haa-hahahha !!... so if it dies when you pull it allllllllll the way back... don't pull it back that far![]()
Patient: "Doctor, my arm hurts when I do this."
Doctor: "Then don't do that." (Ba-Domp-Domp)
Hey Traffic don't you have an interesting story about a problem with the Idle Fuel Mixture on a C-172 in flight? Something about the engine dying on short final? Maybe?![]()
no problems up here, even when it is 0 to -10F like it was today. As long as the engine was in the green it ran good, but when it was cold, it didn't really want to run below 1000rpm.This happened to be every once in a while in recips when it was cold. My guess is the fuel is just not vaporizing readily at that temp, so when you pull the throttle back all the way there's nothing to burn. I would definitely talk it over with the mechanics, but this could just be one of those "know your airplane" deals. I used to fly a 182 that always had low temp and high pressure on the ground, but after a few minutes of flying it was fine.
Can any of our friends from up north chime in?
