F9DXER
Your in the soup, and the forcast was wrong, again. The breifer said freezing level was supposed to be at 9000, and your at the MEA of 6000. Tops are reported at 17000. You are over mountains, and the nearest airport is 40 minutes away, along with the possibility of a lower altitude. You can't turn back because it's getting worse behind you. Do you deal with the ice, which is going to cripple you airplane, or do you climb up above it and deal with Hypoxia? The airplane you are flying is turbocharged with a service ceiling of 25000. The O2 bottle is empty.
Rember MEA is the lowest published altitude between radio fixes that meets obstacle clearance requirements and in most countries ensures acceptable nav signal coverage.
Not to throw a curve into this but he just said you were over mountains and not in a designated mountainous area
Either way you are guaranteed at least 1000ft of obstacle clearance.
As previously stated - how familiar are you with that area? In this day of gps do you really need signal reception.
A lot of variables come into play.
Maybe the best case would be to declare an emergency and let atc help you out.
Remember pilots report to ATC current conditions first before (if at all) sending a pirep, thus ATC might have more information available, plus the benefit of not trying to find flight servie frequency.
