BravoHotel
Good afternoon ya'll.
I have queries pending at the IACRA help desk regarding my question , but I thought I might post it here and maybe get some input, and potentially have this info for someone else who might need it.
I have an appointment with my local FSDO to remove the restriction from my ATP. I am trying to complete the IACRA application to do so. There is no "remove limitation" as there is on the actual 8710 form.
I work through the system and I select ATP Certificate, Standard and it lists several methods 61, 135, 121 etc. So I select 61 given it is the most correct answer, later in the application it states since I have ATP Certificate I can't proceed with the application and or it tells me to add a category or class, which is not what I am trying to do.
I can't advance beyond this step to submit the application. Any guidance is appreciated.
Thank you.
Thank you.
