When this baby hits 88 knots you're gonna see some serious shiz.routed through the flux capacitor.
Dude common sense plays into this a bit as well. shaking engine aint going to make me land in a field. Now if it is like hurling pieces of it in every direction then I am going to try to miss the cows...but short of that. I did mention mixture, and if that solved the problem great...I may or may not continue the flight. Knowing the cause in this scenario really does nothing more than shorten the length of the conversation with the mechanic. Roger was able to figure it out as an A&P with the description you gave which would probably be pretty close to the one I would give a mechanic...so i'm pretty sure another A&P can figure it out as well.The mixture knob, full rich. Then if the engine smooths out land at your leisure, tell a mechanic you believe have a plugged injector, probably the number 1 cylinder since that's where the EGT probe is, go grab some lunch and come back to continue the flight.
OR...
Declare an emergency, land at that uncontrolled virtually abandoned field below you because "the engine is coming apart." Call the flight school and tell them that you refuse to fly the airplane due to their shoddy maintenance. Rent a car and drive home cursing the entire way.
actually... now that I think about it, I'd prefer the second option since it means I'll get more flight time going out to rescue the airplane on your dime!
Knowing a little bit about systems, in this case, saves you money.
Again i still think it's trivial from a strictly opperational standpoint. If my actions solve the problem great. i recognized a problem existed and i used resources to solve problem. There is nothing I am going to be able to do to an injector in the air to save the day.
If you know how it really works, and the prop starts acting up, the first thing you think is "how's my oil pressure/level" and start looking for an airport.Another retro example already mentioned.
You know how the prop governor works and how to opperate it safely.
I think it is powered by squirels and can opperate it safely.
Who is the better pilot? You because you know how it works? With that knowledge what can you do to the prop in the cockpit that I can't (shy of laughing at me trying to figure out how to feed the little critters in the prop hub)?
lol probably right about where i sit. As I said WAy back in this thread i tend to take the extreme argument. Being able to operate the systems and know there limits and how they interact with other systems is the bare minimum. more than that and you get into theory. theory I'll leave up to the individual to decide the importance of.
Being a good A&P doesn't make you a better airman...it makes you a better mechanic. i know broad sweeping statement...mainly for effect.
I'm fighting a losing battle...I know i am but I've got nothing else to do...so "Into the breach men!"
Good point sir, but my example was VERY much to the extreme. i would be inclined to say that oil pressure is a general concept of prop operation...one that be easily seen by looking at a gage in the cockpit while changing RPM. I would say that the prop Governor uses more and less oil pressure to change the blade angles. When oil pressure is lost in the hub, the blades will go to high/low pitch. That to me is a very basic description of the system that allows the pilot to correlate that to other systems of the aircraft.
You push the prop control lever in causing......speeder spring.......flyweights to........pilot valve allows........I would consider superfluous information. The more you know great. One should always better themselves. but not required knowledge.
I like to think I am fairly middle ground compared to the extreme parts of the discussion. I teach systems thoroughly but i am no mechanic. in fact FAR from it. LIGHTYEARS in fact. i contend though that as a PILOT I am just as competant as the next guy at my experience level on either side of the argument.
What button can you push to resolve this situation in the cockpit?
I wish we had ejection seats. Still trying to convince the chief we need to pick up a dozen surplus T-37. If that fails I'm just going to buy a fighter pilot helmet off ebay.Eject.
