BobDDuck
Island Bus Driver
How many large, fast aircraft have turn coordinators?
It's built in to most glass displays in the form of a sky pointer and a coordination "brick".
I dunno. Every plane I've flown with a sky pointer is pretty damn sensitive to bank angle changes.Isn't that just the "ball" part and not the "rate" part? The plane I fly has a sky pointer and isn't nearly as sensitive as a canted gyro.
As originally designed, I believe the Brasilia actually did have a turn coordinator.I actually have a theory now (god help us all).
Rate of turn is dependent on angle of bank and true airspeed. A higher true airspeed requires a steeper bank angle to achieve a given rate of heading change than an aircraft travelling at a lower true airspeed.
It is more common for small aircraft to have turn coordinators, and large aircraft to not have them. I suspect this is because if you're shooting along in a skyhawk at 110 ktas, a 2 or 3 degree bank angle won't take very long to get you off course, whereas if you're shooting along in a Pilatipi at 260 ktas and you lean over into a 2 or 3 degree angle of bank, you are going to hear someone yell "hey knucklehead, straighten us out!" long before an actual heading change occurs.
So really by offsetting the gimball in the turn coordinator they just made it more sensitive so you could fix deviations more quickly.
You're correct. Jets don't have any rate of turn indication. This is because unless you're doing less than 180 knots your maximum allowable bank angle isn't enough to give you a standard rate turn anyways.
