B767Driver
You are cleared to an arbitrary point in space...and are RNAV (FMS/GPS/INS) equipped. Let's say that point is the ATL 300 degree radial at 40 DME.
Here's my question. Can you hold on any direction from that fix...or only on the radial from the VOR that identifies the fix?
For example...can ATC clear you to hold South/North/East/West of the ATL300RAD/40DME fix?
Or can ATC only clear you to hold NW and SE of the fix (on the 300 deg radial that makes up the fix)? (Without RNAV...this would be the only way to hold at this intersection.)
I've always thought using RNAV, ATC could instruct you to hold any direction from this waypoint. Am I mistaken? I've been told I'm wrong.
