Landis
I've done some searches in the forums, looked at the AIM, the P/CG, 7110.65, etc and am still confused.
The situation is what is the proper terminology to expect when being told to hold at a GPS waypoint?
The confusion comes in the exact word that is used. From 7110.65 we see that a controller should issue the "Radial, course, bearing, track, azimuth, airway, or route on which the aircraft is to hold." (7110.65T 4-6-4 c)
The controller wants the pilot to hold north of WAYPT waypoint.
Which should this be specified as:
Hold N of WAYPT on the 360 bearing from WAYPT
Hold N of WAYPT on the 180 bearing to WAYPT
Hold N of WAYPT on the 180 course
I'm familiar with the "Course is TO, Bearing is FROM" argument but the P/CG doesn't back that up.
So the question is: What SHOULD the controller give me when wanting me to hold due N of WAYPT waypoint?
BEARING- The horizontal direction to or from any point, usually measured clockwise from true north, magnetic north, or some other reference point through 360 degrees.
COURSE-
a. The intended direction of flight in the horizontal plane measured in degrees from north.
RADIAL- A magnetic bearing extending from a VOR/VORTAC/TACAN navigation facility.
