tgrayson
As another instructor told me this morning, just do whatever ATC says and you're good to go!
No, that is a terrible recommendation, unless ATC is actively vectoring you.
OK. I thought that was your logic, which I think is a common mis-conception. I think. Not saying I'm right, but my understanding of the system is that:The AIM can't possibly consider every contingency, so a little common sense is in order. The holding pattern is a one minute maneuver, by definition. ATC isn't going to expect you to carry it past that and may be basing traffic separation on that understanding. You need to tell them if you're going to do something unexpected.
If you are holding over a fix with a normal approach PT, when ATC says "cleared for approach" (with no other restrictions) the approach airspace has been opened for you
How close to the centerline of the inbound course must you be in order to be considered "established" so you can start your descent? Is there any reason that you must wait until you are wings level on the centerline before starting down? If you decide that you can actually start your descent as you are finishing up your turn onto the final, how much time does this give you to get down to altitude at the VOR? What descent rate would be required? What if you flew the outbound leg for one minute at 120 knots and then slowed to 90 knots when starting to turn inbound - how much time/what descent rate will you need then? What happens if you are still a couple hundred feet high at the VOR? Can you still make a stabilized descent from that point and safely make the runway (assuming you break out by minimums)? If you cross the VOR at 2500, are flying at 90 knots, what descent rate will you need to hit 2.1 DME at 1620? Is this acceptable and safe?
What if you had made arrangements with ATC prior to entering a hold for extended leg lengths (longer than your standard 1 minute)? Thinking of holding while waiting for conditions to improve here...
Wanna show us the math on this? lol I hate doing mental math in the cockpit, I should buy a little calculator and put it on my kneeboard.
To be arguably established, you need less than full scale deflection. In some situations, though, even a half-scale deflection can put you outside the protected area for the segment of the approach you're on. Not in this situation, however, since you're so close to the VOR.
Prudent technique is to wait until the needle is pretty much centered. Cutting corners suggests that you're behind the airplane and that increases the likelihood of making mistakes.
...but you're going to be hard pressed to do the latter if you're in anything faster than a C172.
Why would aircraft speed make any difference?
It shouldn't make any difference if the hold is based on time. One minute leg will need 1700 FPM regardless of the speed of the aircraft.
It will make a difference if the legs are distance based rather than time.
As I recall, the FAA doesn't define "established" for a VOR, but I'm pretty sure the ICAO does.
All true, which is why I said "arguably". But even the ICAO definition is made without regard to the capabilities of the navigation system in use, particuarly when you throw in the ±6 degrees of allowable error in our VOR receivers. Operationally, I would argue for less than 1/4 scale deflection.
Ahah. Is your line of thinking that "established" should keep me within terps'ed airspace at the maximum allowable error?
