Guam to Jacksonville, FL in a Lancair 4. In the air now.
He made it.
Configuration 3 is single place with the tanks listed for configuration 2 plus: copilot footwell and seat tank (rudder bar with no right side rudders installed) 44.5 gallons. Copilot seat to gear box tank, 44 gallons. 2 soft drum tanks, 66 gallons each and a soft cushon tank on top of the copilot hard tank, 37 gallons.
Empty weight: 2068 lbs CG: 88.6
Total fuel capacity: 443 gallons, Staying within published CG limits limits fuel to 399 gallons.
In this "expedition" configuration the tenaitive max gross weight is 4,800 lbs. We plan to test up to this max weight in small incremental increases. Estimated minimum runway at this weight is 7,000 ft, sea level, standard day. Calculated stall speed is 86 kts. Estimated still air range 6,000+ nm.
I guess the range is now 7000+. 39H 16m
Does this guy have a website where you got this information?
Nevermind, I found it.
Jeesh, I've done a couple decently long legs in the 767 (ferry from JFK to Kuwait, for instance), but nothing near this long. Amazing. Crazy, but amazing.
This is crazy!! I use to be amazed by single engine planes stopping in Vanuatu on their way to Australia, with 14-15 hours legs on their shoulders
