jrh
I feel kind of stupid for not understanding this, but I guess a good pilot is always learning...I've had this question in the back of my mind for a long time and never bother to ask anyone what the answer is.
I've read in several textbooks that best glide speed varies with weight. A heavily-loaded aircraft will have a faster best glide speed than a lightly-loaded aircraft.
This is because best glide speed is based off of flying at a specific angle of attack that produces the most lift for the least amount of induced drag. That AoA will occur at different airspeeds depending on weight.
I believe I understand all of these facts so far.
What I don't get is this concept--textbooks say an aircraft will travel the same horizontal distance across the ground while gliding, regardless of weight. It will get there faster at a higher weight, but the total distance a gliding aircraft can cover remains the same.
I don't agree with this concept in theory, or in practice. I don't think a heavy aircraft is able to cover as much ground as a lighter aircraft.
The way I've reasoned it out in my head is that if the AoA remains constant, the induced drag remains constant. However, if an aircraft is heavier, it must go faster, and if it's going faster, it must have more form/parasite drag. If it has more drag, by definition, energy is getting wasted. Therefore, a heavier aircraft's total energy (Kinetic + Potential) will reach zero sooner than a lighter aircraft's.
Another, less scientific way I think about this is that if a plane needs to go faster to maintain a certain AoA, the nose must be pitched down. If the nose is pitched down, the "aiming point" will fall closer to the plane than if the pitch were higher.
But all of this contradicts the textbooks saying, "A plane will glide the same distance at best glide AoA regardless of weight." So I know I'm probably wrong. But what piece am I missing? How can this scenario be proved mathematically?
