NoSoup4U
Soup are you familiar with Starting Strength
Do you mean starting a strength training program for beginners?
I believe he means Mark Rippetoe's Starting Strength program: http://en.wikipedia.org/wiki/Strength_training
That is amazing to hear, as it sounds like you are great athlete, and know a lot about health and fitness. So, that puts you ahead of the game in regards to dialing in your routine. Chances are, you'll benefit more by changing the target workout like I mentioned to different rep ranges, loads, and goals for each workout.
That is also a good sign that when you are rested you can't tell the difference in how you feel when comparing your shorter and longer runs. In regards to body fat, without a doubt, being lean allows the body to function more efficiently within reason on course. You'll simply have to keep tooling with it a bit to see how low you can personally go without seeing the detriments of too low of body fat percentage where your hormone levels begin to shift in negative directions for optimal health and fitness. Everyone will be different in that area. I have tested this on myself, and I can hold 6% BF for as long as needed without any negative side effects. However, appetite begins to grow a bit, the "fun" factor with foods isn't nearly as great, it takes more psychological "tuffness" to maintain and not break from the exercise and nutrition routine. Those are trade-offs though, and you can definitely relate that when you are an athlete, it means enough to you to maintain. The best strength to weight ratio a person has, the better a person will perform.
The next question you have is more challenging because there is a lot of variables that come into play, and you'll have to play around with things a bit to get it right for you and the way your body is feeling. It's good to know you are doing short explosive running training like 200 meters intervals. The rough part about being a marathon runner, yet still want to maintain a strong body, is that the resistance training program has to be scaled down or up according to how you feel after various runs, and to find that "sweet spot" that works well with your athletic lifestyle and goals. It's definitely normal to still feel the fatigue after a couple days of lifting while doing your runs. However, now we have to find a way to have you feel a tad less fatigue, and have you increase strength and power enough to hold a faster pace when you doing your long and quality runs. The eventual goal is to keep improving your pace in which you can run long distance as a marathon runner. That is done with quality speed work like you are doing in your 200 meter training, and to find a pace in which it's very uncomfortable in regards to lactic acid and H+ accumulation in the muscles that lead to the "burn".
I definitely see what you're saying about fitting your lifting schedule into your run schedule. That is without a doubt a controversial topic considering there are so many ways to organize it. If it were me, I would actually do your strength work on your recovery run days. So, your example would be shifted like this:
Day
1 Morning- Quality Run
Afternoon- Rest
2 Morning- Strength
Afternoon- Recovery Run
3 Morning- Quality Run
Afternoon- Rest
4 Morning- Strength
5 Morning- Quality Run
Afternoon- Rest
6 Morning- Strength
7 Morning- Long Run
Afternoon- Rest
In this manner, the aspects of training that mean the most to you, improving strength, power, and speed in your resistance workouts, and then endurance and pace during your runs all get the most effort from the body. By separating the difficult target workouts for resistance and quality runs on different days, you allow the body to put forth the most effort it can on the workouts. As you notice, I also shifted the strength workout (make sure to get at least one meal or proper supplementation in before training) to the beginning of the day before your recovery run so you can put max effort into the resistance. Since the recovery run is easier, it can be done in the afternoon sometime after getting in another meal after your strength workout. I Just don't recommend performing the strength workout and immediately doing the recovery run (unless this run was something short like 15-20 minutes). The reason being that the longer the workout is extended the more drastic negative shift occurs in natural hormone levels, as testosterone decreases, and cortisol increases, which leads to excessive breakdown/degradation of muscle tissue, more soreness, and increased recovery rate, all which isn't beneficial in which you are trying to accomplish. If memory serves right, I believe this was roughly around 48 minutes of exercise or so. I usually make my workouts no longer than an hour, unless I am doing a long endurance run, but I have plenty of nutrition during exercise to help combat some of the negative side effects.
Since your goal is to maintain or improve cardio, and also increase strength and speed, it would be beneficial to do lower reps/higher weight in the workouts. So, you may want to do something like the below variations, but find out which works well for you depending upon how you feel in the runs:
Resistance Workout #1: (say we do it on Monday): You can perform a 5-6 rep range for strength X 3 sets with the rest time I described in the previous post as well as how to organize it around choosing 4 different muscles and working between them, then move onto another 4 and so on.
Resistance Workout #2: (say we do it on Wednesday): You can perform a 15-20 rep range for muscular endurance X 3 sets with the rest time I described in the previous post, and this lighter load may allow your joints some rest and recoup.
Resistance Workout #3: (say we do it on Friday): You can go back to your 5-6 rep range for strength like Mondays workouts.
This organization of the three allows two pure strength days separated by a lighter day.
OR
Resistance Workout #1: (say we do it on Monday): You can perform a 15-20 rep range for muscular endurance X 3 sets with the rest time I described in the previous post, and this lighter load may allow your joints some rest and recoup.
Resistance Workout #2: (say we do it on Wednesday): You can perform a 5-6 rep range for strength X 3 sets with the rest time I described in the previous post as well as how to organize it around choosing 4 different muscles and working between them, then move onto another 4 and so on.
Resistance Workout #3: (say we do it on Friday): You can try a new lower rep range with higher weight consisting of 3 reps range for strength and power X 3 sets, and the sets can be more explosive but smooth and controlled like power-lifting motions, but if you feel uncomfortable than do the sets at a normal pace as any other day. To emphasize power training, the speed of movement must increase. You'll be performing more work over a given period of time to produce power. Just be reallyyyy sure to warm-up incredibly well and do the movement flawlessly, as this rep range will have an increased chances of injury, especially when not done correctly.
This organization emphasize more strength and power as the week goes on.
Now with any of the choices above, there are even more combos that I'm sure you can make, and that's a good thing. You'll adjust it to what your goals need to be. What you still want to maintain is the principles behind it, which are progressive overload within the same week and from workout to workout, as well as strength every 48 hours. If you feel the volume is too high, simply adjust the amount of sets you are performing (doing less not more sets), but this may only be needed for your legs. If you need to only do legs 2 times per week with strength, then do so with a good split of time in between like on Mondays session and Friday's session. Or, keep doing legs 3 times per week, and try performing only 2 sets instead of 3 so the total volume of work is decreased.
In regards to the fiber question after workouts, it isn't recommended because it may lower the Glycemic Load of the meal, and in-turn slow digestion, and not spark insulin nearly as high. If this occurs, the body won't take nearly as large of a shift in recovery from a catabolic to an anabolic mode. You want the meal to digest as quickly as possible so increase insulin and glucose levels and get the nutrients into the blood stream and muscles and fast as possible. Fiber in general after a workout slows digestion rate (even though some speeds things up, but it's still not recommended after the workout), as does fat (which you probably won't have more than an average of 2g after a workout or so).
Also, here is a great article by a very well known physiologist, and it's a great read.
http://www.unm.edu/~lkravitz/Article folder/lactatethreshold.html
Good article. It pretty much covers what I've read. If I can't shake the lags before I hit the interval focus phase, I'm gonna try that schedule and see if I can get better quality rest. I haven't had too much of a problem during taper phases, but I still feel like I can perform better earlier if I get better rest, which is pretty much what is happening during tapering. I'm focused mainly on 5ks and 10ks right now but the reason I stopped leaning at the slightly higher body fat was my inexperience with dealing with the issues that come with training and low body fat. Now that I've been maintaining it for a year, I feel more comfortable with adjustments. I'm still getting faster in the 5k, so I'm gonna stick with it for now. If I'm still having fun when I stop improving the 5k, I might very well move up to the marathon and do some 10ks along the way. Thanks for looking at my schedule!
I have a "Scotty dog" fracture of my L6? It doesn't bother me now. What are my treatment options?
Currently it is still "broke". Only found it because I was in for a kidney CT. I compete in Olympic weightlifting and it doesn't bother me but the doc(s) seem to think that in a few years I will need it fused together, thus ending my weightlifting career (I have masters level world records to break here).
Holy thread jackpot! Thanks Soup! Where did you go to school? I am going back (better late than never) and am looking for a similar career path.
GREAT info on this post!!! especially since I'm really quite new to the circuit training cliche.
I'm doing 6 months, 3x week, circuit training to lose some serious weight (at least 50lbs)...with that, I'm also doing a carb cycling lifestyle change with the diet and all. What I'm finding is that during circuit training, my hands are not used to holding my weight and the weight training gloves I'm wearing don't seem have enough padding or something.
at 45ish, Would it be better to work on the strength of my hands or get a new set of gloves?
If new gloves, is there any particular type that has added padding (over regular weight training gloves) that I should look for, that will do the trick? I saw some boxing spar gloves that had some nice padding on the outside (obviously wrong location for the gloves I need) and wondering if there's gloves out there with that, that might be recommended.
Also, if I do strength training in my hands, any recommended exercises? My wrists often have "overuse" issues since I'm on the computer typing away all the time and my grip is starting to suck but with pushups, burpees, mountain climbers...it's the outer skeleton and inner palms along with the fingers that are smarting.
I figure they'll be smarting for a while till I lose some but still, it would be nice to not damage them further...HAHA
Thanks!![]()
Thanks!![]()
