drunkenbeagle
Gang Member
Well here is my thought, and by no means am i sure if i am right in this...
Switch tank procedure:
1. Make sure to start timer (e.g count down on transponder) - Risk for complacency.
2. Make sure to have enough altitude when switching tank, in case not enough altitude defer switching tank to later time, that means there is risk of forgetting to do this.
3. Make sure to have somewhere to land within glide distance when switching tank, in case you don't defer switching tank to later time, that means there is risk of forgetting to do this.
It isn't that complicated. I wouldn't change tanks at 500', but how often are you cruising that low?
If you forget to switch tanks, you are going to notice in less than 30 minutes, as the trim will start to be noticeably off. The "reminder" of the plane banking for you only gets stronger as time passes.
Also, I don't understand the fear of running a tank dry. I mean, no one seems to have this fear of running a tank dry when they only have a "both" selector. If you do somehow manage to run a tank dry with a left/right switch, you at least know that there is fuel in the other tank, and the engine will restart in a few seconds.
