Does anybody use this math for crosswind correction in a hold? It seems kind of complicated to try to do while flying?
That's pretty much it. For jollies, I pulled up my copy of the old Java applet, Tom's Navigation simulator and set up the scenario I mentioned earlier:just take SWAG and adjust from there. O wait I'm in an advanced aircraft now....The box will figure it out and fly a perfect pattern...
It wasn't perfect, but it was pretty darn close. And if it wasn't a direct crosswind and I overestimated the correction? Big deal. The protected airspace is designed for 200 KTS and imperfection.
Actually, all laps are free when it comes down to it, unless ATC tells us otherwise. The 2011 Young interpretation deals with a number of subjects, one of them leg lengths for DME holds. Not your 1-minute pattern, but sounds like it should be applicable...Whatever happened to "The first lap is free"? Some people need to channel their inner-Maverick and do some of that pilot....stuff.
I think it's the fault of the way a lot of instruction is done. We teach primary student pilots to use an tiny graph on an E6B and a blunt pencil to calculate headings to the degree based on guestimates of future winds aloft and an approximation of TAS. We compound it during instrument training, treating the 70° line in the AIM-standard holding pattern entries as though being on the wrong side will lead you to fall off the edge of the earth. That would play into anyone's tendency to focus on the trees and be blind to the forest.When I was instructing, I'd make my overly analytical students calculate our turn radius at different speeds so they could see how far from the edges of protected airspace they were. Some still fretted about 1 degree heading changes...in an R-44...in turbulence...
Some people just can't be saved.
