formula for crosswind correction in hold
Mavmb
Does anybody use this math for crosswind correction in a hold? It seems kind of complicated to try to do while flying?
Reminds me of Junior High math.
I did have some very analytical students and I had to do equations for most things for them to understand what was going on. If I had them for instrument training this would have worked out as well.
I couldn't watch it all (gives me a headache) but, browsing through it, ultimately he talked about needing 8° correction to maintain the inbound track and therefore expecting a 24° correction for the outbound leg. That's just the basic 3X rule of thumb. And "adjusting a tad" is hardly the height of mathematical computation :D.
It's actually one of the earlier videos in the series that is much more math intensive - using the Pythagorean theory to try to get a precise method of estimating the correction that might be required for the entry other than direct along the inbound course. Unfortunately, even that requires at least DME.
I see a Garmin 400 in the video. It flies holds nicely. Do that. Use your brainpower for things like SA.
I look at my 430 screen that shows Track vs Desired Track any time I'm in the air. For some reason the 530 doesn't have that feature.
I find that the same folks who are smart enough to figure out 8* needed for what ever are the same ones who can't hold +/- 10* to save their life.
Huh??? Are we talking about the same ting?
(The yellow arrow is mine; the picture is the default set-up of the 530).
I agree, but I don't think the question is about how much correction is needed to have a good reference heading to keep a courseline centered.
Although the videos deal with GPS, which really makes the whole thing a no-brainer, the underlying problematic issue is the course correction for an outbound leg that is not preceded by flight on the inbound course in which there is no course guidance.
Example: No GPS. In fact, make it no DME either. The hold instructions are to hold southwest of the VOR on the 220° radial. You are heading to the VOR on a course of 340°. Nice basic entry, and in no-wind conditions, you simply turn right to 220° when crossing the VOR for the entry. But add a wind - 130@30. You need to come up with some number to subtract from the 220° in order to avoid being blown closer and closer to the inbound course.
