Flying into Boston in a SR22
navymmw
Hey everyone, last monday my instructor and I did a flight into Boston from Nashua, NH in a Cirrus SR22. I was sitting in the right seat and recorded both the take-off and landing, we then proceed on to Nantucket, then back to Nashua. I don't have any videos from the last two flights since my instructor was teaching me about high performance aircraft.
Here is the take-off
Cirrus SR22 Take-off from Nashua, NH - YouTube
Here is the Landing
Cirrus SR22 Landing in Boston, MA (KBOS) - YouTubehis flight was alot of fun, it was my first time in a Cirrus, and first time flying into a major airport. Going into Nantucket we flew a full ILS to minimums, which was my first time landing in actual IMC conditions, quite a learning experience for me since i'm currently a Instrument student.
In the first vid of the departure, and with 0 time in that aircraft, why was the power brought up in what sounded like 3 stages? You can even see the RPMs come up 3 different times after the roll is started.
I know I sometimes ease up the throttle in the Cirrus while stabilizing the direction of the plane during takeoff. It really wants to haul to the right when full power is applied and if it happens before you can get enough airflow over the rudder (castoring nosewheel) it can make for a squirrely ride down the runway. I definitely don’t do it in stages but a more smooth measured addition of power. Just my experience.
haul to the right??
It's the prop control that's linked to the "power" (and I use the term loosely) lever. The prop control moves up through notches, increasing RPM as the lever is moved forward. Very annoying during a full throttle cruise, the prop is turning 2700 rpm. If you're careful you can bump it down to 2550 with little loss in TAS for a quieter ride.
Thanks, did a quick google to read more and found this. All is clear, RPMs are increased with the single MP/RPM control and I guess it bumped up the RPMs 3 times during the roll. It
just sounded weird the first time I heard it. Props not full forward for T/O...whaaaaaaaa?
http://www.avweb.com/news/newacft/181605-1.html
Another slight departure from the norm is in the engine-management hardware of Cirrus airplanes: A single lever to control throttle and prop, plus a mixture control. Although I'm not completely sure how it works, for the pilot the difference comes out like this: you don't have to worry about the propeller governor control. As you move the throttle from idle to full power, the linkage sequences the governor to full rpm, then back to a pre-set level as you retard the throttle lever that allows the prop speed to drop and manifold pressure to remain high. Pull the lever back more, and the manifold pressure starts to drop, then engine speed again, and finally, you're back off the governor altogether.
