PilotDefenseAttorney
I think if you mean by "not properly executed" there was some structural defect in the drafting of the agreements/contracts the risk of an enforcement action is probably pretty low. On the other hand, if you are referring to the operational arrangements that result from such improper agreements, I think the risk is significantly higher. Remember, despite the fact that the rules - as we have seen in this discussion - are complex and subject to varying interpretations, the FAA has demonstrated that the pilot-in-command of the airplanes involved is expected to be something of a gatekeeper in these situations. Ultimately, the actions of the FAA will likely be tempered by the perceived intent of the parties. Was the overall intent to circumvent the regulations, take advantage of a technical loophole, or simply avoid detection? Under such circumstances, the likelihood of enforcement is pretty high. If on the other hand the parties made an honest mistake in trying to operate in a accordance with a recognized exception or exclusion from the 119/135 requirements - and when called out on it take immediate action to rectify the situation - I think (at least formal) enforcement action is much less likely. Obviously, this is one of those areas that can turn on the reasonable discretion of a particular FAA inspector.
