Flight Tracking
GrantHubbell
Me and JC user Alex_B are sitting here in study hall and wondering if there is a flight tracker for general aviation. Alex_B s brother is ferrying a 172 to Wisconson. He left this morning at 5 am est. Is there anywebsite where you can track GA aircraft.
I know about the commercial tracker under "pilots toolbox"
Thanks
LOL.....study in study hall ??? study hall to us used to be a goof off period
I'll have to check on this -- someone in my flying club told me that he saw me flying out of the ADIZ!
I wonder if it's because I have a discrete transponder code that they can track me?
Yikes!
yup, if you're on with ATC with a transponder code assigned, they have your N-number as well. This is what most of the flight tracking software uses. They pretty much just use the ATC feed of your N-Number in the system. So, if you're flying VFR, 1200, then you can't be tracked.
Ah ha! So all I have to do is change my squawk to VFR and then I'm all set.
Of course, that sets me up to be intercepted by a Customs chopper carrying men with guns who will want to talk to me. I saw that Saturday and that was not a pretty sight.
So I guess big brother will be able to track me.
by couldn't be tracked I wasn't referring to ATC!
They can track you just fine! I just was referring to the commercial flight tracking software. Those only display aircraft on a instrument flight plan since all the planes details are entered in the ATC system.
But I wasn't flying IFR. I can't, yet.
Didn't file an instrument plan, just an VFR ADIZ plan.
Yeah, but you had a discrete transponder code. When I was training in Florida and needed a transponder code, even in VFR opps due to shuttle operations, they always had the type of aircraft, N-Number etc. along with that code. That way, all the area radar facilites have you displayed on the screen with all your info, so technically, you were in the ATC system, which is where that flight tracking software get's it's data. If you were just flying squaking 1200, the radar screens would still see you, but you would have no other details displayed, other than altitude and speed. So the tracking software has no n-number associated with that specific radar target so it doesn't display the data.
Well, that makes a lot more sense.
I guess any time you're flying with anything other than 1200 the software can track you. Guess that means if you're getting flight following, they can track you, too!
Wow, talk about a great tool for stalkers. Get your N-number and then people can say, hey, so and so, what were you doing in such and such place?
no, you CAN track IFR GA aircraft. You can track any aircraft that is on an IFR flight plan, or even a VFR aircraft that is assigned a unique transponder code, ie. the ADIZ, etc.
edit: actually, make that you CAN track GA aircraft under those conditition if you have this software. I haven't found a free tracking software that provides the level of access to track anything outside of the airlines.
http://www4.passur.com/bos.html
There is a 10 minute delay I believe, but with this you can track aircraft within 90 miles of major airports (just subsitute the /bos.html with /jfk.html or /lax.html etc.. It only has a few airports, but I think that this is an extremely cool website, and I believe that it includes all GA flights also.
