finished 221 today
yeah 222 sounds significantly more fun
221 wasnt bad but i dont feel like i learned too terribly much. certainly not like 102 (for obvious reasons)
221 is mostly there to build solo XC time and to introduce you to IFR flight so its not as big of a shock when you hit 222. But the big majority is to build solo time for the 141 instrument rating requirements. You will learn lots more in 222, and its alota fun as well. Just get used to the damn hood!!
:yeahthat:
and also try to keep on template because if you dont you will be here past the end of spring semester.
:yeahthat:
ill be here anyway attempting to take summer courses
that and i dont really have a "parents house" to go "home" to. (a bit too old for that.)
Congrats, are you taking 222 ground with Tina Anderson? I need 1.8 night hours here which is holding me back right now since UND closes at 4:30PM. Did you take a break or went all out with the sim flights?
2 per day on sims
and cant register yet (since i just finished, duh)
Well whenever I do finish I plan on doing 222 with Tina, she is pretty fun if her classes fits your schedule.
very nice. you should go over to GFKFS and get checked out in the cadet for free. ;) (note that is a ground only checkout)
ah i was wondering what their specs were for the checkout deal...
so finishing 221 = free ground checkout in the cadet? not bad. whats the rate on that thing these days?
65 + gas, which if you are capable of leaning you burn about 7gph and cruise at around 110-115 :D
same vspeeds, etc as a warrior, just less gross weight
So we're talking about $90ish an hour for the cadet. What's the arrow run?
20 more, and the fuel burn isn't that much more either. i did a BFR in it this week and we only burned 9 gallons i think. note with more than 1 person in the cadet it doesn't get the same speeds and will cruise just like a warrior only maybe up to 5kts faster
