Filing IFR to shoot an approach?
Don't file...unless you need to to get out. Just fly VFR and grab a pop-up for the approach. And just ask for the approach from the IAF. No need to bother with a STAR.
That sounds more like shooting a practice approach while VFR.
A pop-up (I think most would agree?) would be asking for an IFR clearance,
Ymmv depending on where you're at. Around here (TUL), I typically file a local IFR flight plan when I take students out in actual. Though it's not the only way, ATC here prefers we do it that way.
Filing is a better strategy than not filing and intentionally being VFR into IMC.
I believe they are suggesting not filing, and then asking a clearance delivery for a "pop up" style clearance, while still on the ground. Might as well file, the only thing you gain by cutting the corner is having someone else do the work for you that you should be doing yourself.
Why would asking for a pop up IFR clearance be a VFR practice approach?
To answer the OP, the most consistent method would be to file. Pop up IFR requests are a lower priority (practice approaches in general are too, but I digress) and a lot of facilities won't issue them as a matter of policy unless you call flight service. The ATC manual instructs us to tell pilots to file through AFSS for IFR requests.
I work at a place with a lot of practice approaches so we do pop up IFR all the time, however in some areas it's often denied. If you file, you'll have your bases covered. If you don't, you're rolling the dice on ATC assistance.
You asked the guy the question.
I read "pop up" to imply IFR but I guess that's not universal. I was confused as to why you said it sounded like a VFR practice approach when the guy you replied to was asking about getting a pop up IFR clearance (though he abbreviated it as just "pop up"). I need him to clarify, I read it to mean he was suggesting IFR.
I would routinely do this with students when I was a CFI... never even filing a flight plan. Called up clearance delivery asking for local IFR.... I'd VFR on top for maneuvers and then get clearance back in for the ILS (always letting the student fly it so they could experience the real deal!).
Clearly there are two different suggestions here..... lol
There's really nothing wrong with a pop-up. I've gotten them many times, practice or not. One pretty funny one was when I was doing a practice approach VFR under the hood, using ATC services. Already being vectored, my friend (safety pilot) said,"you'd better look up" and when I did we were heading toward a cloud bank. Pop-up clearance took less than 10 seconds.
But that's not the point. I've been denied too . Pop-ups are still workload permitting and, as someone else pointed out, you are basically asking ATC to do your job for you. Unless you are in an area where local IFR clearances from the ground is the norm, I don't really see a good reason not to file when the reason for the flight is to use the system.
Because he was already on the approach VFR when he for a pop-up. Too late for separation.
But ATC can certainly start separating. In the VFR to IFR in the middle of the approach I mentioned, separation wasn't an issue. But altitude was. Approach was using a lower altitude for VFR practice approaches than for "real" IFR approaches. So, the very first instruction I received when my IFR pop-up request was granted was a 1000' climb.
BTW, I think he was only talking about location, as in, don't bother going as far as you would go to fly a STAR back in; you can ask to begin the approach closer to home at the IAF.
"No practice approaches"
"I need a real approach..."
A pop-up is requesting an IFR clearance, but avoids the hassle of filing on the ground and getting routed all 'round god's green acres. You only gotta give type, equipment, and requested approach. You get IFR for the approach and only the approach. Kinda the best of both worlds. Probably only works very well at Deltas, D-TRSAs, and occasional Charlies.
Sorry if you read it that way. That's not what I meant. I meant to ask for the pop-up (IFR clearance) when you are outside some IAF. Get the clearance, and fly the approach... as a "real" IFR approach. We do this routinely on VFR training flights just due to fickle Wx. Many times as we return to the Airport, the Wx goes IMC, so we have to do this.
This is what several people here are referring to. Just including this for the OP, or anyone else who may want to see it in writing.
From AIM Pilot-Controller Glossary
ABBREVIATED IFR FLIGHT PLANS− An authorization by ATC requiring pilots to submit only that information needed for the purpose of ATC. It includes only a small portion of the usual IFR flight plan information. In certain instances, this may be only aircraft identification, location, and pilot request. Other information may be requested if needed by ATC for separation/control purposes. It is frequently used by aircraft which are airborne and desire an instrument approach or by aircraft which are on the ground and desire a climb to VFR-on-top.
(See VFR-ON-TOP.) (Refer to AIM.)
Maybe in Kansas where there is very little traffic.
If your path is crossing other IFR aircraft (final to different airports / runways) or you're 2 miles in trail of an IFR aircraft both of you established on final you can't. You really need to give ATC a heads up much further out if you're going to ask for an IFR clearance.
I'm all for asking for a clearance in the air when it's needed but make it easy.
Totally acceptable. Though, we'd expect it to be to a full stop (unless the missed approach was required) and, as an airfile IFR request, there may be a delay in issuing the clearance if sector volume is high.
A clearance to execute an instrument approach necessarily implies clearance to execute the missed approach procedure.
(I'm just being difficult here; there's a courteous, and right, way to do this, versus the not-right way.)
Or in quite a bit of the US, where there is very little traffic :) There is a lot more to the country than California and the Eastern Corridor.
If you look through the posts, you'll see you and I don't disagree on this subject. Not even a little.
