PFGiardino
N18040, I had specified "piston" because of exactly what you pointed out.
However, after reading what TGrayson has to say, I have new thoughts on the relationship between the engine drag and the windmilling prop. These thoughts are still in development, so do not take them as fact.
If an engine fails, the propeller will gradually lose RPM until it reaches a windmilling equilibrium. To bring the propeller from its powered RPM to a dead stop would take tremendous energy (specifically, the brake horsepower at which the engine was operating). Have you ever pulled the mixture in a single, pitched up, and waited for the prop to stop? I haven't gotten far enough to let it stop, but can tell you it would require a slow relative wind.
In other words, we aren't starting to windmill a propeller from zero RPM, which would require the use of forward energy to turn the blades and crank the engine (aka drag). We're simply letting the propeller slow down until it reaches that windmilling point, and since the crank/pistons were already turning, that windmilling will far impart less resistance than the zero-to-windmill scenario (static vs moving coefficients of friction). That resistance will involve much less drag than the effects of the aerodynamic events around the prop.
