JSFirm Fairchild Metro Pilot
Status
Not open for further replies.
NewsBot
Administrator
4M HR Logistics Houston, Texas:<BR /><div style="text-align: center; ">&nbsp;</div><div>&nbsp;</div><div><strong>Fairchild&nbsp;Metro Pilot</strong></div><div>&nbsp;</div><div>This position would require the candidate to live in the Houston area.&nbsp;</div><div>&nbsp;</div><div>Performs pre-flight, in-flight and post-flight procedures in accordance with FAA and Company directives.</div><div>&nbsp;</div><div>Performs operational ground checks, taxi checks, post maintenance functional check flights, general aircraft systems undergoing maintenance and determines in accordance with technical publications and Company procedures, the airworthiness of an aircraft prior to flight</div><div>&nbsp;</div><div>Performs troubleshooting procedures of an aircraft on the ground and in flight and makes appropriate (verbal or written log entry) recommendations to assist ground personnel in correcting deficiencies.</div><div>&nbsp;</div><div>Instructs maintenance personnel for aircraft ground run-up and taxi operations to prepare aircraftKeeps abreast of and complies with FAA and local flying regulations and safety procedures as applicable for the job.</div><div>&nbsp;</div><div>Maintains proficiency in basic flight maneuvers, appropriate aircraft emergency procedures and instrument flying consistent with technical publications and Company requirements.</div><div>&nbsp;</div><div>Briefs and demonstrates operational and emergency procedures to passengers</div><div>&nbsp;</div><div>Instructs contract aircrew on flight procedures and maneuvers.</div><div>&nbsp;</div><div>Perform other qualified duties as assigned.</div><div>&nbsp;</div><div>Knowledge &amp; Skills</div><div>&nbsp;</div><div>Experience &amp; Education</div><div>HS Diploma or equivalent</div><div>&nbsp;</div><div>Minimum a FAA commercial certificate/instrument rating with single engine and/or multi-engine commercial privileges.</div><div>&nbsp;</div><div>Minimum total time of 2,000 flight hours (all types of aircraft).</div><div>&nbsp;</div><div>Minimum of 250 hours in the Fairchild Metro Aircraft.Shall obtain an FAA class II Flight PhysicalRated or designated aviator experience required</div><div>&nbsp;</div><div>Check Flight qualified on Metroliner aircraft highly desired</div><div>&nbsp;</div><div>Impeccable safety/mishap record.</div>
Continue reading...
Status
