Well today I failed my single engine add-on. I am pretty disappointed right now but will hopefully get a chance to fix it up before the weekend. I had strong crosswinds on runway 8-26 (150 16g28). Took off soft field no problem maintained strong slip and almost full airelon. Went and performed chandelles and lazy eights no problem. Then went to do a steep spiral. Winds aloft were 30-35 knots and I did not maintain my point as well as I could have but passed satisfactory. Eights around pylons I pitched down and up a ton to complete the maneuver. Went back did shortfield and soft field (which was a little crazy with such a strong crosswind. I had used 20 degrees flaps for these landings (big no-no in strong gusty crosswinds). On the next soft field take-off I forgot to take out 10 flaps until I was about 600 feet turning crosswind. Power off precision I turned left base very early knowing my base leg was gonna be really slow with a 30+ headwind. I was slipping hard right rudder left airelon right until base then I started to setup for my slip to landing and skidded the base to final (another big no-no). I was still high so I added some flaps. No power flaps and a little bit or airelon jockeying. I landed in the right spot but caught a gust of wind that momentairly caught right wing. I was now full right airelon right tire on the ground. So failed the checkride. The conditions were difficult which served as a distraction exploiting my technique errors. I learned a lot on this checkride and failed it not because of bad winds or anything else....I just messed up. Fix it this weekend!
-Jason
-Jason
