FAA ASAP asking for a job code?
saxplayer72586
Hey all... I've been out of the loop for a while. I had a pretty crappy ATSAT score and have not been able to get picked up... and it will be a year pretty soon so I'm trying to reapply on ASAP so I can retake the ATSAT. Looks like theres only one application available right now w a closing date of sept 30th. I click apply and it asks me for a job code... this is different from the other pubnats which I've applied to... where can I get this .job code. ? Anyone? THANKS A MILLION!
That announcement is for CTI Grads. If you are OTS then you will have to wait for Pubnat 8 which is rumored to be coming out this summer sometime.
I'd call ratheon who administers the test. They probably can schedule you directly. I called them when I had to take the ATSAT the first time and manually selected where I wanted to test.
ratheon took over i believe
I went through robinson a year ago so maybe ratheon didnt take over testing.
Raytheon took over training in OKC. Robinson still does AT-SATs. However, calling Robinson up isn't going to do much -- because they won't let somebody just take a new AT-SAT off the normal schedule.
For the OP, your sig says that you applied to subsequent PUBNATs, so I'm assuming that includes PUBNAT7. About the only way I can see you being able to redo a PUBNAT would be if PUBNAT7's geo preferences were delayed until after a year from your original testing date. But it's unlikely that they'll have to wait that long, and with 5/6 already on the referral lists, it's too late for anything earlier. Even then, you would need to try to convince them to let you join a group already taking the AT-SATs, like PUBNAT8's or possibly a group at a CTI school (which'd be a long shot)... they wouldn't set everything up and provide a proctor for just one guy, after all.
So... you'll probably need to wait to test with the next PUBNAT, and even then, it'd still need to be a year after that original date. Probably the best thing you can do at this point is to call the FAA up and ask them what they think your options are. They'll almost certainly say "You'll need to wait and see what dates roll out for the next PUBNAT's testing," but they're the people you need to speak with, not Robinson.
