Look up how a F-16 trim system works sometime.
But this gets back to the basis of all your assumptions, that a secondary control system (trim) is keeping AOA constant.
Therefore for you to proclaim inviolable "rules" seems a little presumptious.
Here's another scenario. I'm in a sailplane, and I want to climb. Do I pull back on the stick, or do I push up the nonexistent throttle?
Many of your "Core concepts" are the direct result of propwash of a single engine over tail surfaces of a GA aircraft. Your rules DO NOT generally apply to any other type of aircraft, especially high speed jet aircraft.
In steady flight, a sailplane is always descending in the body of air in which it flies. If that body of air is rising, then the sailplane may rise in relation to the earth, assuming that the air is rising faster than the plane is descending. Pulling back on the yoke may convert a descent into a cilmb if the resulting higher AOA moves it closer to the point of minimum power required. The aircraft's descent rate is at a minimum at the minimum power required airspeed, which is theoretically at .76 of Vldmax.
Now, the airplane has a velocity which can be converted into altitude on a temporary basis. By zooming, in other words. This is a simply conversion of kinetic energy into potential energy. Still, the energy height of the aircraft will remain constant.
Power and thrust curve analysis do not take into account zooms or any kind of accelerated flight.
You have to understand it very, very well, or you will confuse yourself as well as the student.
In this case, (as well as the general case) pitch controlls climb and descend.
Thrust, or in the case of the sailplane more or less drag, controlls airspeed.
This is quite a true statement.
Here's a compromise. You keep on teaching poor students your "core concepts" and we'll keep correcting them once those pilots get to the next level.
I have a better idea: Why don't we each compare what we're saying to a standard aerodynamics textbook?
In fact, I have one sitting in front of me, written by a Professor of Aeronautical Engineering at the US Air Force Academy, Thomas R. Yechout. Perhaps you have it? It says "Based on a 15-year successful approach to teaching airfcraft flight mechanics at the US Air Force Academy."
I'm interested in how you can explain even the simplest of aerodynamic formulas, such as ROC = (Power Available - Power Required)/Weight, or Sin(Climb Angle) = (Thrust Available - Thrust Required) / Weight. (pages 108 and 109).
You've made a lot of indefensible statements, including such absurdities as my core concepts are due to "prop wash" that I'd like to see you defend them. So far, you haven't defended any of the statements you've made and now you want to bail.
Granted, if you cob the power on an aircraft trimmed for a certain airspeed, it will start climbing at that airspeed sooner or later. It will enter a phugoid to settle at a climb rate and eventually a new cruise altitude as well. But you are not CONTROLLING this aircraft.
You are letting it fly itself and meander its own way through the sky.
Actually the threads author and I (and several other posters)have been discussing CONTROL.
You have apparantly been letting uncontrolled model aircraft fly through the sky to crash somewhere.
Actually, the OP wanted to know "why", not how, and he hasn't posted since the original question.
Geez, I wonder why?![]()
Tgrayson,
A question for you. How do you teach your instrument students to track an ILS glideslope?
Honest question: What is the definition of "teaching it right the first time" vs. "dumbing it down?"
But, back to my question. Who defines "teaching it right the first time?" For this discussion as an example, do I need to teach my students physics to teach it right? Do I need to make them work coefficient of lift problems?
I totally agree. But there are various levels of knowledge to answer this statement with, going from PHAK-type knowledge to physics.
The normal way. Small changes in airspeed will result in rate of descent changes. In other words, elevator.
