They should expect at least 500fpm like sigler posted from the AIM. If that's all you give them and they need more, they will ask for more.I just mentioned the hard alt. because that's what I'm using to figure out if I need to hurry down or not.
I've put 500 FPM as a decent rate cuz I saw no hurry to get down and burn up fuel and go slower. Occasionally I'll have a captain tell me "You should pick up the pace, ATC expects "_____" for planning."
Not like I'm going to start a fight over it with the captain but just wanted to make sure that as long as I don't get a time restriction or a specific FPM in the descent, 500 FPM or greater will do the trick.
Thanks for the response.
500-1000 feet/min until I hit the descent angle for the arrival we've been filed/cleared/are expecting, then a more "optimal" rate (usually more like 2000-2500ft/min most of the time is what the descents are figured at) after that.I just mentioned the hard alt. because that's what I'm using to figure out if I need to hurry down or not.
Well I tried...nothing a delaying vector won't solve.
This is a bs answer I know...
What we expect is that you descend at the "normal" rate for your aircraft type, and how your company normally operates...
Confused enough? Sorry, but that's what we "expect"
Certain airlines climb/descend differently obviously, so when lets say Company A usually waits until after the "average" TOD and drops like a rock, then when another aircraft from Company A comes along and descends at 500FPM, it is unexpected and may or may not affect our plan
Don't worry however there's always plan b,c,d,e... Plan F is never an option
Just reach up and push for DES....done. Fifi does the rest.
"We've got the field and all the airplanes in sight, cancel IFR, request flight following and to transition the Bravo to San Francisco, sir."Plan B: Give me a good rate,
Plan C: Expedite
Plan D: Turn left/right
Plan E: Immediately
Plan F: Contact the next guy ie frequency separation
Plan G: Squawk Standby.
Good thing I still have plan G.
I love the AIM "optimal rate" guidance. 500mi from the airport, the optimal rate for my aircraft is "0"...
I usually do 500-1000. If ATC wants something else, they will ask for it. I also try to watch TCAS for the traffic and ancticipate their needs...
