NovemberEcho
Dergs favorite member
Do you guys have portable radios there?
My guy we are in Philadelphia no portable radio setup is going to reach to northern NJ
@NovemberEcho
Do you guys have portable radios there? Like if sht hits the fan can you run a coax with a magnet mount antenna and at least have something in range?
I know it sucks but if I were in your shoes I'd ask around and see if you guys would split the cost of a radio, antenna and coax to cover yourselves.
Do you have the direct line orange boxes at PHL? I assume even if you do they are still remote via Westbury?My guy we are in Philadelphia no portable radio setup is going to reach to northern NJ
That's... embarrassing.We turned CDPLC on at our Center last year, and we were told by the Cadre guys that have done this at every ARTCC that “Monitor” frequency changes were turned off specifically because SWA wasn’t doing them correctly, and their company freaked out when the FAA requested them to give their pilots extra training on the “Confirm Assigned Altitude” function. So they decided it was easier to just make folks keep checking in even with a CPDLC Change.
I use it mostly for crossing restrictions and re-routes, which has been super helpful. But for everything else I find it almost easier to just use voice.
@NovemberEcho
ICOM A120
Radio Includes: HM216 Microphone DC Power Cable Mounting Bracket Microphone Hanger Necessary Hardware Items needed: antenna designed for your particular operating frequency plus mount and cable terminated with a PL-259 connector. VHF Air Band Mobile Radio Icom’s A120 air band mobile...theantennafarm.com
+PL256 male connector
ICOM K220A 108-512 MHz Aviation - VHF - UHF Tunable Mobile Antenna with Magnetic Mount - 12 ft RG58A/U coax cable - Connector Choice
ICOM K220A 108-512 MHz Aviation - VHF - UHF Tunable Mobile Antenna with Magnetic Mount - 12 ft RG58A/U coax cable - Connector Choicetheantennafarm.com
Like Palmdale wouldn’t get nuked if LA was.Centers are remote and often not geographically associated with their facility name.
Plllllllease turn that on. Southwest will eventually catch up. So much time is essentially wasted verbalizing a frequency change, changing to it, waiting to jump in when there’s a pause, you’re stepped-on, spend about 10 minutes on the frequency, then another frequency change.
If this is a crew qual/training issue the way one fixes that is by TRAINING THE FRAKKING CREWS not punishing the competent.Plllllllease turn that on. Southwest will eventually catch up. So much time is essentially wasted verbalizing a frequency change, changing to it, waiting to jump in when there’s a pause, you’re stepped-on, spend about 10 minutes on the frequency, then another frequency change.
“If I hit REJECT, can I stay with CZQM?”
As I am sure you are doubtless well aware some of that smoke is coming from inside our own building.Once I get out of KZMP, Canada is blissful hours of “MONTIOR XXXX on XXX.XX” until we get to Anchorage and it’s “WAOOOO! Hey dawg, check in wit’ ya onboard pippin’ that Tree- Six- Zerrah. Nina One SHOOGA POP Herky DURR”
I find Anchorage to still be blissful. Not as blissful as Canada obviously.Once I get out of KZMP, Canada is blissful hours of “MONTIOR XXXX on XXX.XX” until we get to Anchorage and it’s “WAOOOO! Hey dawg, check in wit’ ya onboard pippin’ that Tree- Six- Zerrah. Nina One SHOOGA POP Herky DURR”
6 years I monitored guard on the strip of coastline from PDX to ANC and never heard a single meow.I find Anchorage to still be blissful. Not as blissful as Canada obviously.
my grandpa on my moms side was a telecom engineer for MaBell during that time period. I guess he had his name on a bunch of their patents.You'd like to think words and phrases all mean the same things, but they don't. "Redundant to a bunch of nines" means different things to different people. For some people, that means reasonably weather resistant cables run through a shielded conduit and a sign that says "call before you dig" every 3 miles. For other people, like say MaBell back in the day, it meant "sunken, hardened, lead lined tunnel, protecting 100% EMP proof cabling along divergent paths, with multiple, independent power supplies, good up to a 20 MT airburst".
There's a reason old MaBell buildings had no windows.
I wish. Especially for over flights that are essentially just “Hi, Bye”. No need for me to talk to the ANA crew flying to Mexico City when I could just text them that.Plllllllease turn that on. Southwest will eventually catch up. So much time is essentially wasted verbalizing a frequency change, changing to it, waiting to jump in when there’s a pause, you’re stepped-on, spend about 10 minutes on the frequency, then another frequency change.
