I'm wondering if there's a correlation to running 25ROP - that seems very hot to me. Most of the reading I've done lately points to running further ROP like 100-150, or LOP (assuming IO-XXX with decent injectors and 6pt EGT/CHTs).
I used to have a ppt from an engine management seminar that talks about the Red Fin area, plotting intra-cylinder temps and pressures at various mixture settings. At a range around peak there is the highest probability of doing badness to the engine.
Which engine, what power settings were you running, etc?
Yes the hottest point in the cylinders occurs at about 50 ROP on the EGT, conclusion, the EGT is useless. Going based of the CHT's, especially if you have individual CHTs for each cylinder, is far more accurate. You are also correct in your 100 ROP or 20-50 LOP as better EGT selections than 25-50 ROP. Each of these better selections will yield cooler CHT temperatures.
As for running LOP, it is highly recommended as long as you have the equipment to monitor it. As for having the equipment for it to work, you need metered fuel injectors. Many people will say GAMI is required, this is, IMO, and from my reading, is not true. Most newer injectors are metered well enough to run LOP without an issue, the more important aspect is individual CHT's to ensure you are not running any cylinder too hot (or too rich in LOP ops).
The belief that GAMI is required I believe stems from GAMI injectors being the original founders and pushers of LOP operations about 15 years ago. When their injectors were introduced 15 years ago, the competitions injectors were not nearly as accurate as they are today. GAMI's are still, IMO, the best on the market for metered injectors, but they are not as far ahead of the competition as they once were.
Any mechanic Guru's want to verify this? I have done a couple days of research, but I have no actual experience in testing/operations of various injector types.
