z987k
Only option left.Roll inverted and pull.
I've got an even stupider scenario.
N12345 - Tower declaring an emergency engine is running rough/out.
Tower - N12345 remain clear of my airspace.
What do you do?
lol.
You are flying a Cessna 172 and your engine goes out at 3,000 AGL 5 miles from KACY approaching from the south you can go staight in runway 22 but the winds are 130 @ 10 Gusting 25 Knots Do you Circle and Land Runway 22 or Try For Runway 13, Runway 22 You have to land and Hold Short Runway 13-31
Runway 22-04 is 6144 Feet Available Landing Distance is 4000 Feet
Runway 13-31 is 10000 Feet Full Length but you must push the aircraft off before the next arrival
What do you do?
As far as landing at a closed airport when ACY is available and has emergency equipment: Why on earth would you do that?
Well, first, the C172 has a about a 700' altitude loss for every 1nm horizontally (approx.) in no wind and a windmilling prop... So you're looking at a minimum of 3,500' AGL (700ft altitude loss x5nm from airport = 3,500'AGL) to make the airport on the numbers. My guess... because you're doing a flow check, and wont be spot on, add in the "oh •" factor. So, closer to 4,000ft AGL. Secondly, if you're south of the airport, you can't physically be "straight in for Rwy. 22" you'd be looking down 04 if you're south of the airport (which is what the conditions are) flying northwards. Third, to answer the question, I'd go straight in for Rwy. 04. 90 knot crosswind at 25 knots which is a 25kt. crosswind component, and max. demonstrated crosswind component is 15.... yeah i'd go for it. I've done 29 knot straight crosswind and landed just fine, 25 ain't no thang. ;-)You are flying a Cessna 172 and your engine goes out at 3,000 AGL 5 miles from KACY approaching from the south you can go staight in runway 22 but the winds are 130 @ 10 Gusting 25 Knots Do you Circle and Land Runway 22 or Try For Runway 13, Runway 22 You have to land and Hold Short Runway 13-31
What do you do?
Land. Get out. Walk to the tower, and proceed to whoop some @$$ .I've got an even stupider scenario.
What do you do?
lol.
What do you do?
lol.
"Tower, November 345, up yours."I've got an even stupider scenario.
What do you do?
lol.
