Does anyone know of the NTSB report or other news report that shows why the engine quit? How did he get it restarted twice but then had to put it on the roadway?
Far be it from me to speculate on the cause of a not-an-accident, but it certainly acted a lot like my lawnmower when I forget to top it off with gojuice and then forget that I forgot and start it again. Just sayin.
:yeahthat:It sounded like the squirrels went on strike, I wonder how many he's got under the hood of that thing.
Will tell you in about 20 mins its on the local news. Happened in cent. FL
That guy did a great job! The ground came very fast at them... at what altitude do think they were when the engine first quit? Maybe it's just me, but it looked like the airplane didn't glide a whole lot?
He may have just taken off...WOW nice job! When that guy in the right seat started clapping i was like, "It aint over yet buddy!" Good note to self that if you are going to land on a road land WITH the traffic not against it.
That thing fell like a rock. Did anyone else think they were a little too low over a heavily populated area?
Sec. 91.119
Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
Not trying to knock the pilots abilities but he did seem very low.
My dad is about to start building an Ultra-light Helicopter called a Mosquito. I told him he is building a coffin. Especially when he told me, "All i need is about 20 hours with a CFI before i go fly it."
Any one know what type of experimental that was?
-Matt
If he was out of fuel, I would expect the prop to windmill a bit. It stops immediately every time the engine quit.Far be it from me to speculate on the cause of a not-an-accident, but it certainly acted a lot like my lawnmower when I forget to top it off with gojuice and then forget that I forgot and start it again. Just sayin.
There is no guarantee that the prop will continue to windmill. Depends on how much compression is happening within the engine.If he was out of fuel, I would expect the prop to windmill a bit. It stops immediately every time the engine quit.
