Pardon but- recruise?
Once you begin a path descent in the 737 (at least one with common VNAV software as opposed to geometric) the airplane wants to continue its descent unless it is stopped by a constraint.
So let's say you're on your way down and ATC gives you a descent that would take you below the calculated descent path, to level at 10,000 feet.
The airplane would, of course, level at 10,000 feet. Now they say "cross XXX at 5000 feet".
If you go back into VNAV the airplane will begin a 1000 fpm descent until that calculated path (which is a steeper, idle path) catches up with you, then the thrust levers go to idle and you rejoin the path.
So in that case a lot of folks will "re-cruise" the FMC, or tell the airplane that 10,000 is the new cruise altitude so that it will calculate a new top of descent point so it won't start down out of 10,000 and slow right away, but rather will wait until it needs to to make the crossing restriction.
What irks me is when they recruise after every descent including little thousand foot letdowns while on vectors for an RNAV approach. You have to have a little bit of spatial awareness here. You can see on the display where the calculated path is. It's still there! You're just below it a few hundred feet.
So ask yourself, "what was that calculated descent rate looking at?" - in most cases the first fix on the RNAV approach. So it is probably ok when ATC gives you that lower altitude to remain in VNAV, let the airplane descent at 1000 fpm, knowing you'll reintercept that path at some point prior to, or right at the fix with the next constraint.
Instead its "descend and maintain 5" ok let's recruise...
"Descend and maintain 4" ok let's recruise...
"Descend and maintain 3" ok let's recruise. Geez man!
And I KNOW where they got the idea they had to do that. In the simulator when you are doing a dozen different approaches you recruise between each one because in that PARTICULAR case, there wasn't a calculated VNAV path to begin with!
I'm not saying it's never appropriate to recruise. If you get a crossing restriction that doesn't require you to begin a descent for many more miles... sure, create a new TOD and save some gas. But understand where the path currently is, what it's calculated to do, and then decide if you NEED to recruise or if you can let the airplane fly how it was designed to.
Way too many lab monkeys who are happy to push the button to get the food pellet but who don't actually understand how the systems work.
