Email on Rotary engines in homebuilt
Sprint100
I found this email from a guy I met online during my initial research into rotary engines. I remember killbilly asking about rotary engines and I was going to send him this via PM but decided to post it for all to view...
Hi,
I'm pretty happy with my rotary. I'm currently working with another builder to complete his rotary install, following my proven layout very closely.
Have I had more problems than normal? Certainly the install took way longer than a Lycoming would have. You can read the detail on my web site (http://canardaviation.com/cozy ). There's really no "normal" for putting rotary in a Cozy, and I had a fairly steep learning curve with very few examples to follow. I think the state of the art has progressed and installing a rotary is easier now.
Is it worth doing? The short answer is yes... if you have the determination required to do the work. Engine mounts are available now, but you'll still need to fabricate a custom intake and cooling system.
My original decision to install a rotary was, believe it or not, based on safety considerations. There's no doubt that initial testing was a bit risky, but once the bugs are out of the peripherals, the reliability of the core engine comes into play - its real hard to break these things, and even when they do fail they usually keep running long enough to get you home. By contrast, when a Lycoming fails it often does so catastrophically leaving you instantly with a glider.
Every rotary installation is a one-off and, as such, there are many things that can bite. We cover ourselves with lots of redundancy e.g. duel fuel pumps, injectors, batteries, ECUs, spark plugs, coils, even fuel delivery systems. Redundancy of all these items allows continued flight even when something fails, but also adds considerable complexity and pilot workload.
It took me about a year (on top of 4 years to build the Cozy) to create the rotary installation, and about another year to test it.
I get about 250HP with my turbo 13-b rew. One main advantage of all that power is take-off distance and initial climb rate.
I once took it up to the plans VNE of 190 kts straight & level at 11,000 feet. (I had plenty of throttle travel left). That equated to 269 MPH triangulated ground speed. Typical cruise is closer to 200 MPH because fuel consumption goes up rapidly with increased speed. That's not a failure of the rotary - just a fact of nature.
Oil and coolant temperatures stabilize at around 210F while taxiing on a 90F day. I usually don't use full power for take-off, and on a hot day it's necessary to back off the power and do a "cool off" pattern before climbing out. That was a design trade-off decision - it's better to have slightly marginal cooling on a very hot day than increased drag and reduced efficiency / top speed due to excessive cooling drag. On a cold day here in Connecticut take-off is nothing short of exhilarating, even on half throttle.
If you decide to do it I have a few suggestions:
1. Forget about the engine until you have a fuselage on gear, wings and canard built.
2. Visit and look closely at as many flying rotary engine installations as you can find.
3. Go to Rough-river in 2009
4. Join the fly-rotary mail list
4. Beware of advice from a self-professed expert (who has never actually flown a rotary) named Paul Lamar.
If you have further questions, feel free to ask them on the forum where all readers can benefit from the answers.
Regards,
John
Couple of questions Sprint:
1) What is the weight of the rotary vs. Lycoming?
2) Is there any way to get cooling to the engine without increasing drag too much? Cowl flaps of a sort?
3) I thought you were going to build a Barracuda - why did I think that?
Interesting stuff Sprint - thanks for posting.
I'll get the answer for 1 to you.
2 - In a plans built you can definitely route the cooling and baffling to your liking as long as it doesn't get in the way of other stuff. Every Cozy that I have seen has the cooling ducted under the cowling without the use of cowl flaps.
3 - I was going to build the Barracuda, but chose the Mark IV because it is a 4 seater, has a bigger useful load, longer range, and a smaller engine. Luckily, evening before I ordered the wood to start the 'cuda I found the Mark IV and saw it had 4 seats instead of 2 and could cruise at 200 with a butt in each seat. Plus the Mark IV is a composite plane:)
I've drifted in an RX7 at an event with a stuffed turbo and seals going out. It blew more smoke from the engine than from the tyres, but it still drifted!!
The weight difference is drastic. The block of the 13b is only about 170lbs. But the 13b needs a PSRU(propellor speed reduction unit) and other accesories for aviation use which can make the weight issue a wash or the 13b will be a few pounds lighter.
I haven't found exact weights for the 13b with everything installed so I left out the direct weight to weight numbers. The weight from a RX-7 or 8 can't be included since most of the stuff on the engine will be stripped off.
Thought you were building a 'cuda too, Ed. Didn't know you switched to a canard plane. Have you checked out Velocitys? http://www.velocityaircraft.com/index.html
Oh yeah love that plane. I was going to start but then noticed it was only sold in kit form and it required the 0-540 or 560, I forgot the exact number for that engine. The Mark IV looks like it except for a few things I can deal with or change up. The Velocity is a very nice and luxurious plane.
Edit - Forgot to add that there are retracts available for the mains too. I know of three types, two types make the stance about a foot wider by putting the main struts under the wings and having them retract toward the fuselage. The other type is just like the F-16 landing gear where the struts are angled outward from a housing in the fuselage and retract outwards toward the wings.
