If you want to copy movies, it can be done. Just not a push button operation. There is digital (multiple methods may be used on one disc) and analog protection schemes. Both types can be defeated by software, if you have the DVD burner in your computer. Not perfect, but it can be done.
Problems that still exist though:
DVD-9 (dual layers of info on one side, holds about 8.5gig of info, round to 9gig) is what most movies you rent/buy are recorded in
DVD-5 (single layer of info, one side, holds about 4.7gig of info, round to 5) is the best that burners will do today. Philips, LG, and Pioneer have all announced they will have dual layer burners (DVD-9 format basically) soon, as in like first quarter 2004, by end of the year for Pioneer.
So why does one care? Well, if you are going to copy, it may not fit on a current disc, so you have to compress the files further. DVD uses MPEG2, which is lossy compression. In other words, you lose quality when compressing more. And the advantage of DVD is good quality (as well as no rewind time, and being optical instead of magnetic, and being smaller than tape).
So, in a few months you'll be able to get a recorder that'll let you decrypt, then copy an entire commercial DVD (for backup of course, so the kids don't mess it all up and destroy your original
You can also now, pull out some of the info on the disc, like other language tracks, subtitles, menu, etc, and try and get the stuff to fit on one disc in the current DVD-5 format all recorders are, but that still may not fit.
And, to top it off, there are no standards yet. The main competitors are DVD-R(W) and DVD+R(W). The - format is being pushed by DVD Forum, which is about 250 companies that collaborate on DVD isues. The + format has about 7 or 8 companies, Sony and Phillips I believe being the big ones, that support it. DVD+R may be technically a better way to record, and currently is a minute or two faster per disc. Neither will be sure to work on all players, so be sure to test burn to see if it'll work on your player before the 30 days money back is up, at whereever you buy.
In short, unless you REALLY need it now, I'd say wait for the dual layer writers to come out, and put it in your computer.
Oh, and there is an HD-DVD standard being worked on how too, that'll use a different laser, and support more resolutions in the picture with the future thoughts of HDTV in mind, and wide aspect recording that comes with it as well. That is still a year or two from mainstream though, and will likely also play whatever you make now, so don't let that stop you.
You can get a good Pioneer DVD-RW, DVD-R, DVD+RW, DVD+R drive for around $130 nowadays to put into your computer. It'll support the current formats used, so will 99.99% be sure one of those (either + or -) will play on your current home player.
Confused yet? I can refer ya to white papers if you want the technical specs.
If you just want to put handicam stuff on disc, and don't have a computer, $400 average for a set top recorder seems high to me. Just as VHS players used to be $300 for a good one a few years ago, and are under $100 now. If you need the latest, you gotta pay.
Josh
