What difference does it make to be FAA approved? Do I need to go to an FAA approved school to work from zero experience to commercial pilot? Thanks?
Also, what is your experience of ATP?
A part 61 school is not registered or regulated by the FAA. In fact the FAA does not even know who the part 61 schools are since they absolutely do not require or allow part 61 schools to even register with the FAA.
Therefore no part 61 schools are FAA approved.
A part 141 school is approved by the FAA as far as the course(s) is/are concerned.
ATP is a part 61 school in most of their locations. I do believe one of ATP's (JAX) locations is licensed under part 141 for some (but not all) couses of study. Some others will chime in to let you know their exact status.
Joe
Joe
So ---- what if I go to a part 61 school? Will I have problems passing the FAA exam? Will I have a lesser chance of getting the job when competing with someone who went to a part 141 school?
No, you learn the same set of skills (though they can be in any order part 61 and in a set order 141). I prefer 61 as it's less structured and you can do anything in any order you want. I did all of my solo flights last, if I had done part 141 I would have had to do them in order of the lessons the FAA approved.So ---- what if I go to a part 61 school? Will I have problems passing the FAA exam? Will I have a lesser chance of getting the job when competing with someone who went to a part 141 school?
This has been going around here for a while and it is incorrect...to a point. What you are talking about is examination authority and not all 141 schools have it. I don't have any numbers to back this up, but with the amount of work and requirements needed to obtain examination authority I would assume the schools that have it are the exception and not the norm. As far as their record keeping goes with the feds I have no idea.It has probably changed, as most airlines now ask if you have failed any stage checks or flight lessons, but under part 141 you cant really "fail" a checkride, it doesnt show up on your faa records like a 61 ride does.(i think)
Now, you also take three or so "stage checks" a course, so you have that many more opportunites to fail. Was not a big deal before airlines started caring about failed check rides, and now also stage checks.
