fr8dog
My question is: why didn't you choose the precision approach instead of the non precision? You obviously had time to troubleshoot and feather the engine, you could have levelled off, declared an emergency, get vectors for the ILS and still make it safely... No single engine go around at 800 ft on a light twin; and you ended up doing the ILS anyways, since you knew it was operational.
[/ QUOTE ] When I made up the hypothetical scenario, I was thinking of losing an engine near the MDA, 1000 feet, a few miles prior to the VDP.
You're making too many assumptions about the conditions and timing. All I was trying to do is offer up a couple of scenarios where going missed might be prudent. I didn't say day/night, icing/dry, max/min gross, and about 100 other factors. It's a hypothetical example to help see that there are some scenarios where a go around is reasonable.
It's easy to add things to any hypothetical scenario if you're really looking to bias the outcome in one direction. For instance, if I told you the engine was on fire, then by all means you'd land immediately at all cost.
Instead of adding conditions to the hypothetical scenario that would make a go-around a bad idea, try to see if you can envision a scenario where you could understand (but perhaps not agree with) the point I'm trying to make.
Clearly we don't agree on the performance aspects of a twin doing a missed approach on one engine. I don't know what type of twin you fly, what climate you fly in, but I'm sure it's different than mine. In my environment, I have a reasonable climb on one engine. That's why I mention the 9950' airstart. The significants of this example is that most people wouldn't think a light twin would have this performance. Knowing this performance, and having a lot of experience on one engine, gives me an option than many would not have.
Then maybe you should call it "missed approach" at altitude...
We are not making too many assumptions...we are talking of a missed approach or go around at low altitude due to reaching the map or dh with no vis...
faa says go around
i say : be careful, consider the performance and the statistics that shows that nearly all go-around in part 23 airplanes at dh on 1 engine ended up in a tower or building or something !
Once you are commited for landing (gear is down) DO IT
you seems to be all happy of your performances at 10 g's
Beleive me, i fly part 23 aiplanes for living carrying cargo and shooting hundred of app...i know !
As far as icing/wx/max weight....low vis.... Well the day you will be needing a go-around in actual condition (meaning the wx is low because i don't see why else you would) it's gonna be one of those night where everything went wrong.
Remember, Emergencies tends to be stacking up !
To sum up what we are saying :
The most likely time you would be considering a actual SE go-around would be under bad weather conditions...
We are just saying that if you have time to troubleshoot, that's nice, and ask for the ILS, Once commited, LAND !
If you don't have time to troubleshoot and you're on the approach already...do you have altitude? Can you hold and reverse course for the ils ? Atc still here ? if so cool ! suck the gear up and set up for the ils (plus you got time now to try that boost pump or whatever...)
If you are already low and commited to land, (basically on the ils at 400 feet or so...make sure you put it down, cos that's gonna get ugly if you push 300 hp around the yaw axis.......)
Of course, that's only MY opinion of flying those things 5 hours a day....
And of course always follow AFM/FAA regs.....
faa says go around
