Murdoughnut
Well sized member
I've been reading up, trying to find the recommended methods for ditching over water in a small, GA aircraft such as a SkyHawk, and haven't had much luck. I've found a lot of conflicting advice, so I thought I'd pose the question here - what's the recommended methods?
Here's what I've collected so far...
Preparation
1) Obviously, make sure seat belts are tight and secure.
2) Find something to shield yourself and/or passengers from hitting the panel
3) Keep your hands away from the yoke, and feet away from the rudder pedals as they can move fast enough and abruptly enough to break appendages (can anyone confirm this)
4) Crack the door as in emergency landing procedures
Contact
I've actually heard a few suggestions for this...
1) Normal soft field landing procedure, hold the a/c wheels above the water until stall and brace for impact
2) At a low airspeed, abruptly pull back on the yoke and allow the tail to contact the water first in order to absorb some of the momentum.
3) Stall a few feet above the water and pancake in at as a low of a forward speed as possible
4) Jump out of the aircraft a few feet above water, at as low an airspeed as possible (if in a piston single such as a 172)
Any ideas or thoughts on this would be greatly appreciated. I only ask because I regularly depart over Tampa Bay.
Thanks!
Preparation
Contact
Thanks!
