Richman
JC’s Resident Curmudgeon
Every once in a while a commercial comes along that entirely encapsulates reality in a neat bundle.Damn, commercial blast from the past!
And to that I say "well done"...
Inertial-equipped CRJs (at least here) are unable DME-DME-IRU. No GPS = no FMC position.Whiiiiiiiich is why many systems run off IRU's and only generally use GPS for reference data. You could totally go "Gravity" on the satellite spectrum and the Airbus would put down it's coffee and say "Monsieur, your NAV performance has degraded somewhat" but it's not about to fall out of the sky or end up in the side of a mountain. I'm not even sure the entire 757/767 fleet even has GPS.
On the Bus to go GPS-primary NAV you've got to deselect a lot of stuff in the MCDU to make it happen. 757/767 wouldn't even care. I don't thnk I've flown any aircraft that would disregard IRU data and go following a rogue GPS position.
Trust me, nobody is making an aircraft climb by hacking the ACARS.
Right now, I'm not sure anyone actually could. I don't think the system have the ability to do anything other than read the data that streams in over ACARS. But what I think a lot of people, or at least myself are alluding to is if we decide to take the pilot out of the equation all together, the step from Joey Dispatcher sitting at his desk pointing and clicking passengers around the country to Johnny Hacker taking over his console isn't far off.
I have a friend who used to do acceptance testing for the RQ-7 Shadow. That platform was hacked on multiple occasions from what he says.
You should be able to easily hack any commercial jet aircraft through the CTDU (ChemTrail Dispersion Unit).
opsec… OPSEC!!!!
An E-jet of some sort recently had a generic I/O module on MAU 1 go haywire according to Embraer.TMK Wifi wouldn't be tied into anything on the airlines. As I recall the WiFI is in it's own avionics rack and doesn't even talk to FWC. As far as the plane is concerned it doesn't even exists.
MCC does have access through software to VIEW aircraft data in near real time. I don't think they can do anything remotely other than view data.
I see to recall the E170 at Shuttle MCC could trip remote CB's but that was about it. Can anyone else comment on that is current in the type?
MANY BOTHANS DIED. #toosoonYeah...people keep yelling that at me. That time I was stationed on Scarif...and Endor...
But drooooness!!!!111!1!1Software and hardware assurance is far from perfected in the aeronautical context.
Granted pushing an airplane around from my couch, in sweats, with an Xbox controller sounds pretty darned good, but...But drooooness!!!!111!1!1
Also, I sort of understand most of this now.An E-jet of some sort recently had a generic I/O module on MAU 1 go haywire according to Embraer.
The ensuing mess happened in VMC; ADS 1 quit, the autopilot and autothrottles disengaged, engine instruments wound to zero (both engines were operating), PFD 1 went haywire and displayed things that the airplane wasn't doing, and a cabin altitude warning was posted (although pressure remained in the people tank). Erroneous GPWS warnings were also fired. There were all matter of things that went wrong, but the crew (in VMC) shrugged and landed at the nearest suitable airport.
Nevertheless, one I/O card on one MAU going "kaboom" caused a bunch of trouble.
Great avionics, tho'.Also, I sort of understand most of this now.
It’s p. cool flying the airplane with the CCD.Great avionics, tho'.
There's a little USB device called a "HackRF One" that lets a user receive and transmit anywhere from 1 MHz to 6 GHz. It's only 300 dollars. The much-cheaper receive-only SDR's are what people are using to receive ADS-B info and link it to their EFB's.
I wonder if TCAS could be spoofed? It's not the same as changing the aircraft configuration, but the antisocial act could elicit a response. Like a future generation of kids deliberately jumping in front of self-driving cars.
...and a cabin altitude warning was posted (although pressure remained in the people tank).
