400A said:
Too shallow increases ground roll and too steep increases ground roll, relative to your computed numbers from the POH dependant on how the POH numbers were derived.
I'm starting to think that no one teaches this to primary students.
I don't get it, why would they? Ground roll is a function of kinetic energy which is directly related to airspeed. How much ones ground roll is has to do with their airspeed, not the descent angle chosen.
blackhawk said:
you must follow the vertical guidance to DH/DA.
Just so others know, this was blackhawk's interpretation of regulation 91.129 (e)(3): Each pilot operating an airplane approaching to land on a runway served by a visual approach slope indicator must maintain an altitude at or above the glide path until a lower altitude is necessary for a safe landing.
I agree with that interpretation. Once below the DH/DA of a typical precision system or any airport served by a visual guidance system that should be adequate to be safe to descend below, hopefully the FAA would agree.
Where to land? The numbers or the thousand foot markers, it seems this debate trickled over to this thread. I will speak only of GA aircraft in a quick analysis I would like to throw out here for others to examine.
A typical glide path is built on a 3 degree slope, this would be a glide ratio of approximately 19 and 1. With this glide slope you cross the 200 foot AGL point at a distance of 3816 feet. If one was aiming for the thousand foot markers they would be 2816 feet from the numbers.
Let's just throw in some actual glide ratios now, the C172 glides at 9 to 1 according to the POH, from readings I have seen people experiment getting numbers as high as 12 to 1. Each of these assume no flaps, and obviously aren't calculating glide ratio with full flaps power idle. I would guess with full flaps power idle it is closer to 6 to 1. So I did some calculations based on that.
Let us recall just a paragraph ago that if we aimed for the numbers we must be at least 200 feet or higher at 2816 feet from the runway to remain on or above glide slope. Here is a list of distances at an altitude of 200 feet for the glide ratios mentioned above:
12 to 1 results in 6.4 degrees and a distance of 2382 feet
9 to 1 results in 4.8 degrees and a distance of 1783 feet
6 to 1 results in 9.6 degrees and a distance of 1182 feet
The conclusion is with a C172 at least, an idle power approach at about 60/65 knots will result in these distances, each of which will keep you above the glide slope until you are at or below 200 feet if your aim point was the numbers. I didn't take the time to calculate when in fact you would dip below the glide path with these descent angles, obviously it would vary based on your actual glide angle. My guess would be at a glide angle of 5 degrees you wouldn't dip below till VASI until under 100 feet.
