Delta Upgrade Time Vol. II
I use boards often.
I thought, with modern aircraft, the notion of using speedbrakes means that you screwed something up was over.
With a jet with no boards, and no drag devices at all for that matter.....no flaps or anything...... you had to plan descents accordingly, as well as rejoins. For those who used SBs as a crutch (not screwing something up, but rather in place of actually planning a descent when one could be planned......of course there are times when they are needed in order to make descent/speed restriction combos), life would get very difficult, very fast in many situations.....either effing up airwork, or pissing off ATC. Neither of which has good outcomes.
Derg said:
I use boards often.
Hell, I will deploy the speedbrakes with one hand and be on the phone with all the detractors mothers with the other saying, "Hey, what's up girl?" :)
Our winds in cruise and decent are automatically uploaded in our FMS (im sure yours is too). Going into the decent phase we are as set up as we can be and we've still needed the speed brakes at times especially because the company policy is to not use the flaps to descend until you're in the pattern and slow.
Our winds in cruise and decent are automatically uploaded in our FMS (im sure yours is too). Going into the decent phase we are as set up as we can be and we've still needed the speed brakes at times especially because the company policy is to not use the flaps to descend until you're in the pattern and slow.g
The drumbeat that we have is "flaps are high lift devices and not necessarily drag".
Do you get FMS-uplinked wind updates in cruise?
Most certainly do....and that's the same thought process here.
You guys know the boards work pretty well too, right? And there's a manual speed mode, so you can start the deceleration on your own in manual speed mode, and then pull the boards to keep the descent angle the same while decelerating?
Or wait, do I only use boards because I'm a terrible regional pilot?
Below 10,000' especially, I'm usually descending in flight level change and manual speeds. We're still figuring out how to airplane in this airplane, but the bottom line is that it is still an airplane: pitch is for speed.
"Slow to 210" -click, spin-
Please don't be the guy who is in FLCH who needs to get down then dials the speed back in FLCH when told to slow also.
Please don't be the guy who is in FLCH who needs to get down then dials the speed back when told to slow also.
Nope.
You can have one or the other but you do not get to have both.
There's this nifty red button on the yoke that makes it an airplane again, too. Shocker!
