im covering it in my IR study material, and it doesn't give a very good definition.
all i know is that it's only upon request, and you must have 1 SM C of C to conduct.
Visual approach requires VFR minimums (1000' 3 miles), a contact approach has the same minimums as a special VFR - (1 mile clear of clouds).
I can't think of any situation where you would ever want to request one.
so you fly a standard pattern to the runway?Visual approach requires VFR minimums (1000' 3 miles), a contact approach has the same minimums as a special VFR - (1 mile clear of clouds).
So...did you get some 'situational awareness' here, after reading some situations where a 'contact' approach might be very convenient?I can't think of any situation where you would ever want to request one.
As posted earlier, contact approach requires 1sm and clear of clouds. Same as special VFR.Edit: A contact approach can only be done if there is resonable certanty that you you will be able to see the field, no wx mins as far as I know (other than being able to navigate visually).
Visual approach requires VFR minimums (1000' 3 miles), a contact approach has the same minimums as a special VFR for airplanes - (1 mile clear of clouds).
...and doing this will give you a stomach-sinking feeling, knowing that you lost situational awareness and not knowing what is in front of you as you climb and pray (more so in mountainous terrain).There's no missed approach for a contact approach other than hitting the power and climbing.
Modified it for clarity.
You wouldn't do it to a field that you weren't familiar with, and you need to have some sort of good visual checkpoints (highways, rivers, etc) that will guide you towards picking up the runway/airport environment. I always understood it to be more of a helo thing, but I guess I was wrong about that![]()
