"Other than using a checklist for everything except letting a fart"
Not to belabor the point, but this quote got me to thinking that yes, we use a lot of checklists, but that is in the name of saftey. I would hope that most 61 operations use something similar. Here's a list of the 172 checklists, which ones should/could we do without?
Normal Checklists: Remember, these are checklists, not "to do lists" and only serve as a backup to flows we already know
Aircraft Acceptance
Preflight Inspection
Pushback (yes it is there on the old checklists and it does say "NOT APPLICABLE", but ok, i'll give you that one, but it has been changed on the new checklists i bieleve)
Before Starting Engine
Starting Engine
Before Taxi
Taxi Check
Before Takeoff
Line Up
Climb
Cruise
Before Landing
Go Around
After Landing
Parking
Emergency Checklists:
Engine Failure During T/O
Engine Failure Afer T/O
Engine Failure In Flight
Landing W/O Power
Fire During Engine Start
Engine Fire In Flight
Electrical Fire In Flight
Cabin Fire In Flight
Wing Fire In Flight
Ditching
Icing
Precautionary Landing
Flat Main Tire
Excessive Charge (Full Scale Deflection on Ammeter)
Low-Voltage Light On (Ammeter Indicates Discharge
Static Source Blockage
Please pick for me, if you will, which of these checklists I should stop using if I were to quit and go get a part 61 job tomorrow. Thanks. Fly Safe.
