Cross Country Requirement for Instrument Rating
rajsingh
I had a question about a cross country flight and to see if the entire flight would count towards the cross country hours required for instrument rating.
Take off - Republic Airport (KFRG) & Landing - Central New Jersey Airport (47N) Distance: 55.3 nm.
Due to Class Bravo in the way, the actual flight path distance will be approximately 61 nm.
I wanted to make the return trip via Hudson River and back to KFRG, which means the return leg instead of 61nm will now be approximately 70nm. The Total Round Trip instead of being 112 nm will now be 130nm. There maybe 1 touch & go at KFRG on the way back as well before a full stop, but there may not be.
Would the entire flight count as cross country towards Instrument rating, or should I log two flights, in case the only the 61nm counts and the return may not.
Thanks
It is my understand that it is straight line distance from the departure airport. So as long as one airport is at least 50 NM from your departure airport the entire time flying can be counted as a cross country
Thanks
Count it all.
All that matters is one of the landing is completed at a point over 50nm from your initial departure airport. You can fly from FRG to 47N and then land at every little airport on the ride there and back or simply fly back to FRG and circle above the airport for 3 hours until your fuel is at a minimum and it all counts.
