the only thing on the erj you might be able to consider fly-by-wire would be the thrust levers, they are connected to the fadecs. All the fadecs do is make us lazy, controls the start , ie not adding the fuel, it is automatic. On takeoff you move the thrust levers into the detent and the computer sets the thrust on computed data already entered by someone, ie temp and thrust setting(ALT TO, TO , or E TO on the xrs only) and whether you will be in icing conditions below 1700' agl. The airplane will climb at 1000' / minute to fl 370 from 10,000' while achieving about 300 kias initially decreasing to fl370 at about 240 kias. Roughy .65 mach in leveling off. Every aircraft is different depending on variables. ie newer engines, light load, cooler temps. At fl370 no more than 15 degrees of bank allowed at heavy weights. Aircraft flies nice and stable in all modes of flight. Now if it would only stop doing the honeywell shuffle( it wants to go left or right initially for a turn when cleared direct to a fix from a heading). Those that fly this aircraft knows this tendency. The aircraft is fun to fly.
