BrettInLJ said:[ QUOTE ]
Then relase a mongoose to take care of the snakes. Follow that with a special breed of monkey that eats mongoose, what's special about this breed is that they die off after the mongoose supply is exhasted.
Don't be silly. If there is a large predatory cat being freighted in the cargo hold, you could just release it and that would take care of the loose monkeys. Cricket problem solved! Chief pilot position, here I come.
And Kristie, yes I was being sarcastic.
Doug Taylor said:About 10 minutes prior to push, your ground crew notifies you that one of the inbound boxes, full of crickets, has burst and there's an infestation of several hundred in your cargo bin.
You're about 40 minutes prior to scheduled pushback.
