tgrayson
Interesting article on all issues surrounding course reversals by a guy who helps guide national policy.
http://www.terps.com/ifrr/jul96.pdf
and of course if approaching from the other side, at appropriate altitude, a turn holding is not only not required but must be requested, otherwise the controller is expecting you to continue inbound. controllers only expect the holding pattern course reversal if approaching from the opposite direction and is necessary to lose altitude. further, if doing a course reversal and at appropriate altitude, if you feel you need another turn in holding to get setup you need to let the controller know before re-intercepting the inbound course that you 'require an additional turn in hold..'
nosehair prescribes his own procedure turns. He's a true believer that they are all optional. If you take the three of us, you have the different viewpoints.That language refers to approach designers who "prescribe" a procedure turn. If it's on the chart, then it's prescribed for you.
I'm satisfied that the conditions in 91.175 must usually exist but that (at least in a radar environment) ATC may clear you straight in.
I'm curious.It is completely unreasonable that ATC would be granted unlimited power to waive the PT when they do not have the TERPS knowledge required to do so safely.
1. How does ATC grant a direct clearance enroute. Airways are set up to avoid obstacles, aren't they?
2. How does ATC vector an aircraft for an approach without that TERPS knowledge you spoke of?
3. What is the TERPS difference between being over XYZ VOR at 8,000' with a 20° inbound turn to final after a PT differ from being over XYZ VOR at 8,000' with a 20° inbound turn to final without a PT?
Thanks, tgray, now I can stop worrying about it.Interesting article on all issues surrounding course reversals
kork, vor rwy 35 is an example of a 'hold-in-lieu', which includes a notation in the plan view that states a 'no-pt' when approaching the iaf from what pilots would describe as a 'direct entry'..a 140-degree sector. krog, vor rwy 2 is a similar approach, yet lacks the 'no-pt' notation.
Note that the Rwy 35 approach says that arrivals via airway between R-089 and R-230 are NoPT. If you are arriving between those radials but aren't on an airway, the PT is a required maneuver. Silly? Yes.
Prior to the TAA concept, this was the only means that TERPS provided for sectorized NoPT arrivals. Rogers may not have an appropriate airway to provide the feature.
half the time you will be asked why you began a turn in hold rather than to have proceeded straight in if at an appropriate altitude from any 'direct entry' when cleared for the full procedure. of course we go straight if radar vectored. truly amazing all the subtle details for which instrument pilots, controllers, examiners and faa safety inspectors cannot agree. kinda scary, too.![]()
Agreed. Controllers are often baffled when we do a PT. During training, I try to emphasize to the controller when we're going to do the PT, so that there are no surprises.
The controller/pilot relationship is difficult; neither fully understands the responsibilities or needs of the other, and that's sometimes led to wrecked airplanes.
Controllers will often let or even encourage the pilot to do things that are either illegal or unsafe and I consider it a victory when I'm able to teach an instrument student to recognize those situations and be assertive. (One of the most common is to be vectored to final at altitudes below what's published on the intermediate segment.)
That's the key, no matter how one views the course reveral "controversy."Agreed. Controllers are often baffled when we do a PT. During training, I try to emphasize to the controller when we're going to do the PT, so that there are no surprises.
Heck, communication can even make "illegal" into "legal." Take tgrayson's and my different views on whether ATC can clear you straight in when there is a mandatory PT:
XYZ is the FAF/GSI fix for the ILS approach to runway 14. Aircraft is coming in toward XYZ from the northwest. There's a PT at XYZ. Aircraft is "on airspeed and on altitude."
ATC: Cessna 1234X proceed direct XYZ. Cleared straight in for the Runway 14 ILS approach.
So far, I would say it's okay; tgrayson would say it's not So let's continue the conversation.
Pilot: Can you give me an intercept heading?
ATC: Fly heading 110.
Bingo! Vector!
a controller instructed us to 'maintain 2,000 to the ndb, cleared for the approach'. the initial segment altitude is 2,300. my student asked, 'must i climb after passing the ndb??'
I do think that's very important. A guy I know nearly botched the ILS on his checkride because he didn't receive a switch to tower and on his next transmission, approach thought he was missed approach and immediately issued a vector that took him off the localizer. Had he been proactive, the situation would never have occurred.i had to prompt for a frequency change
Yep, I see that too.funny is always when they reply, keying the mike..
Good catch for the student. Controllers will often give MVA without looking at the plate. I have them say "Cessna 1234X requests 2,300 to comply with the procedure", which has always been granted so far.
