MidlifeFlyer
That's right.Nope. You could do'em both in a J-3.
From the current commercial PTS:
Aircraft and Equipment Required for the Practical Test
The commercial pilot—airplane applicant is required by 14 CFR section 61.45, to provide an airworthy, certificated airplane for use during the practical test. This section further requires that the aircraft must:
[snip]
4. be a complex airplane furnished by the applicant, unless the applicant currently holds a commercial pilot certificate with a single-engine or multiengine class rating as appropriate, for the performance of takeoffs, landings, and appropriate emergency procedures. A complex landplane is one having retractable landing gear, flaps, and controllable propeller or turbine-powered. A complex seaplane is one having flaps and controllable propeller.
OTOH, the CFI airplane PTS doesn't contain this language. Whether that's a simple error or intentional, I'm not sure, but I can definitely see a reason for treating them differently.
What is does say is
A complex airplane must be furnished for the performance of takeoff and landing maneuvers, and appropriate emergency procedures.
Even in the multi to single add-on, two takeoff and landing tasks are required.
