Chris,
I had that Reno approach during my interview. I believe it was the other Jason that was doing it.
I was asked why such a high mins?
see below
[quote[How low can you decend if I have the runway environment but not the runway?
100' over TDZE
Any takers on these questions?
If you are really briefed for the approach you know that what the IAP is calling for is that you land in VFR conditions (1100-4). I believe that this is done because the TERPs provide a mimimum obstruction clearance on the final approach and the two buildings protruding into that final approach at 4800 ft MSL do not meet the minimums for a precision approach to go down to its usual 200 DA(H). Additiionally the fact that this to a parallel runway allows for all planes on the approach to call runway in sight and for ATC to ask for a side-step maneuver to the parallel. This may allow a better flow.
In doing some research, it appears that the TERPS do not allow for a maltese cross on the final approach into RNO because the obstruction clearance doesn't meet the criteria needed to officially call this and final approach. So in lieu of that it is represented as an intermediary approach the whole way with landing conditions into VFR. This is my interpretation and I would love some more feedback. And one more consideration is that the highest obstacle on the final approach into RNO may not allow for a glide slope that is less than 3.77 degrees (the max allowed for precision) and therefore the landing has to be done in VFR conditions.
It is a good reminder to know that the maltese cross on a precision approach that has an altitude indicated can also be used to cross reference the accuracy of your altimeter setting. So if you are on the glide slope and you DME measures the FAF or you pass the LOM, ostensibly you should have the same altitude on your altimeter as indicated on the plate for the maltese cross.
And can you land if you have the runway in sight with visabilty below mins?
NO. "No pilot may land when the the flight visibility is less than the prescribed visibility in the IAP." YES, "Only the pilot can determine if the flight visibility meets the landing requirements . . . "
1. What three (yes only three) things are needed to leave a DH or MDA?
[/ QUOTE ] Here's a different take on that question: One green light for my nose gear, one green light for my right main and one green light for my left main.
Hey Chris, what was that question that Chris was talking about the other day? What determines off an airway (something like that)? Either 5 degrees off course or full scale deflection? Do you remember?
