B767Driver
[quote
So this leads back to my question "Applying the temperature now to convert a volume of fuel pumped 10 hours or 10 days ago will not necessarily result in the correct weight now, right?" It doesn't look like anyone has an experience where weight was mistaken because of a temperature change converting gallons to pounds. And it may be the 3% or so difference has been too small to be an issue.
To be physically accurate, a mass of fuel is pumped into the fuel tank. The mass of this fuel will not change (negating the effects of evaporation). It is this mass of fuel that the engine needs to adequately perform the planned operation.
I stated previously that the volume of fuel will not change (and I stated that due to the fact that the change in volume of the mass of fuel with temp and density changes is miniscule). The change in weight of the mass of fuel can be somewhat more significant.
So, volume, density and weight of a certain mass of fuel will all vary with temperature. To obtain the proper quantity of fuel to complete the flight, be sure to correct the density of the fuel per its temperature.
A different mass of fuel will be required on a very cold day as opposed to a very hot day due to the density change. You are correct in saying that the quantity of fuel you have in your tank "10 days from now" may not be adequate for your planned operation. Let's say today it is 130* F outside and you topped off your fuel tanks. In ten days it is -50* . It is now likely that you need to add more mass of fuel to obtain the volume you desire (your full tank in this case).
Good topic.
Good topic.
