N519AT
Ahh! This is how I change this!
Yeah considering a lot of 525's are owner operated who knows WTF happened. Typical wanker pilot move to blame the poor fueler. He probably just wanted to get some $$ back from the FBO.
Spot on.
So the 525 is a cj2? I wasn't sure the model. He just said it was a citation 525.
Ok. The links that @Houston posted were about the cj2. I'm not sure if the information would be the same if this particular aircraft is a deferent model.
I did actually. Flight aware has it listed as a c-525. That's it.If you have the tail #, just google it and tell us what kind of CJ it is. I'm sure your cousin has it. Don't post the tail # here though.
Cj4 = I dont know because I stopped caring. Plus the aircraft didn't exist when I got the 525 type.
Thanks!Prist application is a total PITA if it isn't premixed. You have to use these stupid aerosol cans and plastic applicators. The mixing was never exact. I hated doing it when I was fueling the aircraft on the odd occasion. I'm sure that 1/2 of the line guys didn't do it right anyway. Think about it this way if the aircraft was fueled with Prist at all other times then wasn't fueled with 150 gallons which is likely 1/5 or less of the total fuel load. IT WOULDN'T HAVE MADE A DIFFERENCE AT ALL. I know I've said it before but some owner idiot got a light came back to the airport and chewed out the fueler. Those bypass lights come on for the wrong reason a lot. I've seen it and I didn't yell at the fueler. The OPs buddy should call me. He didn't do anything wrong. Even if he didn't fuel the aircraft with Prist it should not have made the light come back on.
Also I'd like to know more details about the flight. Did he make it to altitude or not. If not then it certainly had nothing to do with the OPs friend. Check on that for me.
Plus:
This may help clear things up:
Cj1 = CE-525
Cj2 = CE-525A
Cj3 = CE-525B
Yeah, you're going to have to share the story on this one because I really want to throw the flag on this..Not to familiar with light jets, however sounds like something clogged the filter. I would guess it could be gelled fuel from not using the prist. In my short career I have only heard one story from a plane going down because they determined it was from gelled fuel from lack of prist.
Thanks guys.
He was just worried because he really believes he added prist. He's positive in fact. But he's down on himself for the potential risk. He feels bad because he thinks he could have risked lives if he did in fact forget prist.
I think you're spot on. Especially the last sentence. Boss told him not to worry but to just double check prist every time.I was a fueler as a PT job in college. 1 truck was premixed, 1 was a switch, 1 was "none" (5000gal truck for the bigger stuff). If guys wanted it, flip switch, verify prist tank, and pump. It would be very hard to come back and say "you didn't add prist" as nobody (hopefully) is bone dry on fill-up.
I don't have a Citation type, never flown one. I can tell you that I have seen the fuel filter caution on both a CRJ-200 and -900 when going to idle (either in the descent or on landing) and I guarantee it's not a prist/fuel temp issue (oil/fuel exchangers, even in -40C the fuel warms up in under 5 mins with a heavy load and is good thereafter). Either the sensor or a clogged up filter was the culprit.
Sounds like this guy is a jerk (complaintant). I wouldn't worry. If he wanted to make it an issue a fuel sample would have been taken from the plane and truck, not to mention the fueler is an employee and under the FBO/fuel service liability/insurance.
Fwiw- the plane kept flying, by design, in bypass. Turbines burn anything it seems (although the Mx may get large afterwards).
Sounds like the pilot had a contaminant, false indication, or filter failure. Can't blame the fueler without taking a sample/Mx pulling the filter/checking the codes.
Tell your friend not to worry. If he is still employed, his boss probably knows all of the above and hopefully told the guy to pound sand.
