"challenging" arrivals and approaches for a light GA
stradamus
Howdy all-
I'm looking to enlarge and put up some aspproach plates in our pilots lounge... anyone have suggestions on the most complex arrivals and approaches that would be fun/educational/good talking points to look at? I'm specifically looking for procedures that are compatible with GA (~200ktas) aircraft, not 121 type "cross x @ fl230 and 285kias" plates
things like arcs to LOC BC with very obscure requirements, etc.
thanks
This one just because of the uniqueness of the airport itself and the challenges of operating at North Americas highest elevation airport-KLXV, Leadville, CO
http://dtpp.myairplane.com/pdfs/SW-1/09146G16.PDF
The approach procedure itself is fairly simple but add in elevation, the always howling winds, and some bad weather and its gonna get interesting
Howdy all-
thanks
Redding has a LOC DME (BC) that I've done a few times.
And then there's Medford, where the LOC DME (BC) has such a steep descent angle that it's pretty much not possible to land straight-in (while still complying with the approach, anyway).
Here are a few that I have personally flown. They all were a bit different from the "norm".
KEGE LDA 25
PASI RWY 11 from SIT
PAJN RNAV 08
KLBO SDF 36
I think each of these will show the variety of approaches and some of the challenges that pilots have/may/will face.
P.S. Any of the approaches in Greenland are fun. Try Narsarsuaq, Greenland for a fun approach. VERY interesting.......
KASE RNAV GPS-F: http://155.178.201.160/d-tpp/1612/05889RF.PDF
Just did this one in the sim and I have to wonder how is this even legal? When the visibility is at minimums with the MDA so high you have to do a weird phugoid arc maneuver to point the nose down far enough to see the runway, being careful not to dip below MDA while you do it. You're so high when you finally do see the thing you have to do a tightly banked descending 360 degree turn to lose altitude/line up. The only reason this airport is a thing is because a few people with too much money wanted it to be.
It is a bit interesting. You can find a good accident video on YouTube.
I've flown into there in when the weather was down but I flew the LOC approach. A little better on mins.....
Perfect airport for a turboprop.
Howdy all-
thanks
I once flew a 172 from PRX to SAT departing at 00:20. I think ATC was either messing with me or just wanted to keep snoozing. They gave me the BRAUN1via LFK! Not difficult, just stooopid. I decided I was "unable", at least until I got down around Austin.
OAL.MOD6 into SJC is interesting... lots of terrain and typically lots of mixed jet and putt-putt traffic as you get closer...all complicated by SWA trying to barge in and turn it into an RNAV.
FOT.GOLDN7 to the SJC 31s has mountains, ocean, great big inter-continentals to dodge, lots of navaids, and real fun turns right toward the end. ;)
Howdy all-
thanks
ILS Z 19 at KJAC
Someone once showed me this one.
This gave me a headache.
That's not terribly unusual elsewhere...I'll grab some Sunday from Europe that are similar, except starting in the mid to upper teens. Also some solid dual NDB approaches.
I decided to give the MTN VOR 15 @z987k linked a shot in the sim this evening. The Garmin G3000 doesn't even list it, but it was a lot more fun spinning radials anyway.
